no speedo lights! - FirebirdV6.com/CamaroV6.com Message Board
no speedo lights!
  • no speedo lights!
    i have no idea whats going with my speedo lights! today i get in my car and fire it up like usual everything is fine but the lights to the speedometer dont light! the milage shows the high beam indicator works e-brake light works fine but for some reason the rest doesnt light up... any ideas any help is appreciated!
    Re: no speedo lights!
    check your IP Dimmer fuse
      already did and replaced it just in case but they still dont work ... anyother ideas?
        bulb could be burnt out
          uhh i double checked on my ip dimmer fuse and it looked fine but i replaced it just in case and it solved the problem THANKS SMOKE!
