My '98 Firebird has a digital odometre that has faded in recent days and is now all but invisible. I was able to, in the right angle and lighting, barely make it out today and it is still counting up the mileage but it is pretty much invisible. The rest of the dash lights up just fine, just the digital readout. Anyone else deal with this issue?
digital odometre fading
Re: digital odometre fading
Pretty sure you can replace the cluster with nothing special. I think the info is stored in the PCM. Grab one off eBay for 40 bucks and throw it in, the PCM gives it's read out on the digital area.
EDIT: Looks like they're a little more expensive:
http://cgi.ebay.com/ebaymotors/Ponti...spagenameZWDVW
You could probably find a 150mph trans am one though. Anyone know if he could just throw that in and have it read properly?
http://cgi.ebay.com/ebaymotors/1999-...spagenameZWDVWLast edited by 96firebird311; 09-24-2008, 08:36 AM.
The reading does go with the cluster. If you change the cluster you will have the odometer reading of the new cluster. You can however put your read out in the new cluster and that will keep your mileage the same, but it's the problem to start with not having the back light.
The 150 MPH cluster will work, however your tach will be about 2 times the RPM and your oil gauge will read 20 PSI low all the time.sigpic
Originally posted by 96firebird311 View PostOk. Back when I was looking to do something similar, folks on here told me the reading was stored in the PCM/BCM. If you sure it's not, I'm probably mistaken.sigpic
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...3 days ago
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...5 days ago
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...2 weeks ago
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...3 weeks ago
