headlights - FirebirdV6.com/CamaroV6.com Message Board
headlights
  • headlights
    driver side headlight is bright as heck, passenger side light is duller
    the bulbs are new what could it be?
    thanks
    1998 Chevy Camaro 3.8
    1997 Chevy Camaro Z28 - SOLD 7-23-2011
    1996 Chevy Camaro Z28
    2001 Pontiac Firebird Formula
    Re: headlights
    Check the plug on the passenger side one for corrosion. Also, did you accidentally turn the aiming screw by any chance?
    '99 Mountaineer AWD 5.0 - 4300K HID, Some Bolt-ons
    '97 RS - HPTuner, Bolt-ons
    '09 WRX - Aesthetic mods
      Re: headlights
      If it's really dull, like half the brightness, make sure you have a good ground. I once had a problem where all four of the headlights would come on at half brightness. Really weird. Turned out to be a bad ground... a bad connection where the driver side headlight plugged into the main wiring harness. I clipped that wire (on the headlight side of the plug) and ran it to ground. haven't had a problem since.
        Re: headlights
        By aiming screw do you mean the way the bulb goes in and is positioned? I know that the casing from the cable to the bulb has to be rotated a certain way to lock into place. I checked this and both cables into the headlight and high beams are firmly in place. All the plugs are still in good shape, no corrosion.
          Re: headlights
          Originally posted by mjbrunsm
          is your passanger side lens dirty/foggy or scratched up?
          This is what I was going to suggest; how did you change them? When I yanked out the stock bulbs in the closed housing and siliconed in new ones my driver's side is abit dimmer, but the housing is also alot older.
          ~97 3.8L V6 Camaro~
          A few things
          Only Member of Team Hooker?!?
            Re: headlights
            I am talking about the screw at the top of the "housing". You remove two of them to get the bulb out, and there is a third at the top in the middle I believe that lets you aim them up or down.
              Re: headlights
              Oh, well then I'm way off base. Disregard.
                Re: headlights
                Right 98 camaro. And no both head lights are still relatively new, and both were purchased at the same time. Could it be fuse related?
                  Re: headlights
                  I can try that but all bulbs are new.
                    Re: headlights
                    I'd go with the ground idea. If the sockets are old and mishapened, they will keep it from getting a good ground, or, it may be the wiring.
                      Re: headlights
                      switch the bulbs, if the one side is still dull, you know where your problem is
                        Re: headlights
                        hi everyone.
                        update on the headlight issue
                        I found some new bulbs that i bought a while ago as a spare and just swapped them into see and the result is still the same.
                        However i think my passenger side headlight(which is the side with the dull light) seems to be a little bit lower than the driver side. I wasn't sure though it felt like it was just me. I will post a picture later.
                        also another question, is there a place that sells weatherstripping for camaros?
                        I need to replace alot of mine, but mainly I need some for the headlights.
                        thanks
