Could a 3 position (ON-OFF-ON) rocker switch be used in place of the momentary switch that comes with the QTP electric cutout? I can't stand the look/style of the one that comes with the unit and would like to use one that fits in with the switchplate I'm getting.
Standard QTP switch:
Replacement switch: 3 position ON-OFF-ON rocker switch
Good site. Definitely better options than what my search pulled up. So I found an (ON)-OFF-(ON) round rocker switch. It's the third one down on the list of this page PN#7500023:
That should work just fine, right? And I'm trying to figure out what the different types of switches are. I got the SP/DP (single pole/double pole) part, but what's ST/DT part mean?
'99 Camaro
'04 Saab 9-3 Aero
'90 Audi Coupe Quattro
single throw/ double throw. Single throws are generally the usual on-off switches as they have just one throw. double throw is like what you need; on-off-on. From off, you can either throwing it up or down, hence double throw.
