Ever since I've had this Camaro for some reason the rear defrost hasn't worked but I never really cared until recently its been annoying me. What I don't understand is that when I press the button to turn it on the light flashes and goes away. If you ever hit the button all you get is a flicker and I dont know where to start to identify the problem. Any help would be appreciated and its on a 2000 Camaro.
Rear Defrost Problem...
Re: Rear Defrost Problem...
first try to replace the 30amp silver breaker in the left side dash fuse panel with a regular green 30amp fuse. Go from there1997 Camaro LS1 RS
1994 Camaro - Sold
1999 Trans am Vert - Sold
A Few Mods....
Not that I know of, They are connected and I dont understand why the light flicks on when you press the button, it doesn't stay on for any length of time but it just flashes like a short burst of electricity is going through
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...3 weeks ago
