wiring up halo headlights - FirebirdV6.com/CamaroV6.com Message Board
  • wiring up halo headlights
    i got my new halo headlights today.. the dual halo ones with leds.. and was wondering if somebody could explain to me which wires i have to hook up into the fog/running light circuit to turn on the halos seperate.. i saw blizzard's tutorial thread but am not sure which wires control the leds and halos...i could really use some help to get these installed
    Re: wiring up halo headlights
    you can splice the positive wires from the halos into the positive wires of the fog lights, and the halos will turn on/off with your fog lights via the button above your radio. make sure to ground the ground wires of the halos also. thats how mine are set up, never had a problem.
    1999 v6 Camaro M5
    Automatic to Manual converted
    Pacesetter Headers, 2.5" Custom True Duals with X-Pipe and Magnaflow Bullet Muffers,
    !cat, Intake, 3.42's with LSD, MSD Wires, Drilled/Slotted Rotors, Hurst Short Shifter, Tuned PCM
