have been tracing a ground problem today . need some help! no schamtiacs
the issue is drivers side head light works fine .but all other lights are dim.not enough volts to burn . ok but when i switch to high beams drivers side works . pass side is out.could the switch be the problem ? has any one else had this type of issue .
anybody know where i can find schamtiacs them on the net.
