96 Camaro Lights - FirebirdV6.com/CamaroV6.com Message Board
96 Camaro Lights
  • #31
    Re: 96 Camaro Lights
    Like i said, if you want any real improvements, you have to spend more, and get some new housings, or an hid kit.
    1996 Chevrolet Camaro
    1995 Buick Park Avenue Ultra
    --Appearance Moderator--
    • #32
      hids best money I've spent $70 shipped.. ebay seller supervtec Slim HID Xenon Kit
      9006(low beam) 6000k, there plug and play no wiring to mess with.
      just look at the fog lights, wow those things suck, lol...and no I have not be flashed by anybody yet
      • #33
        ^ I have the 6000K in my low beams and used to have them in the fogs which were great. Took out the fog lights for my intercooler so I'm going to put the extra set in the high beams since I can run my lows and highs together if I want. That will be some great lighting. I haven't had too many flash me maybe 1 , but I aimed the beams down alittle more and haven't had no one flash me. But if someone does thry will get 4 6000K HIDS flashed right back at them instead of 2.LOL
        • #34
          how did you go about doing you fog lights, it's such a pain in the *** just to change a bulb..lol
          • #35
            They are plug in an play no RTV or anything , I mounted the ballast right uner the radiator frame ziptied the wires up, too bad I had to get rid of them. But my highs will be brighter.LOL Actually before you put them in the fog light hole, stick a screwdriver in first and push the metal tab forward a little so the bulb will fit an not touch the metal piece in there. I guess the metal piece splits up the light beam (I guess thats why they call them fog lights.)LOL I found it easier to just pull the fog lights out and then put the bulb in so it isn't damaged. Little more of a pain but you'll be able to see what I'm talking about, so you don't ruin the bulb. I was just glad they fit like stockers.
            • #36
              Are the bulbs for the FF75s sealed in?
              • #37
                No. They are H7 if memory serves, and you can replace them with no modifications. They are slightly more in depth to change than your average bulb, but that's just because they are sealed off from the elements, but made to come apart.
