whining thru speakers after WB install - FirebirdV6.com/CamaroV6.com Message Board
  • whining thru speakers after WB install
    So ever sense i bought my wb o2, when ever i have it hooked up and the radio on, it whines pretty dam loud.
    Now i have tried everything ti can think off and cant get it to stop
    different speaker amp whining
    different grounds
    ground loop isolator (from deck to speaker amp)
    different deck
    re routed wires (made sure non of the power/signal wires were close)
    anyone else have any suggestions? Is there something i can put inline of the wb power/ground wires that might help?
    also i have the gauge powered by the "ign" spot in the fuse block and grounded to the ground block right under the drivers side, side panel
    Re: whining thru speakers after WB install
    ground them in the same spot maybe? as in a shared ground wire...might be worth a shot.
      you may need to get some type of suppressor wire
      back in the old days before they had that, they used to put a metal box type thing on top of the distributor to block the interference from the spark plug wires: http://www.web-cars.com/images/vette...SC_6026A_a.jpg
      im not really sue if they have anything to go over the wires.. but if i had to guess, the wires are not the cause, it is the o2 sensor itself
      it seems that you have tried everything i can think to recommend you, i have heard installing a capacitor can reduce noise
        http://www.radioshack.com/product/in...79&tab=summary
        A Toroid choke basically disrupts the flow of electricity along the surface of the insulation on signal wires and cables... worked in my Camaro, as I had a AC/DC power inverter that caused all kinds of noise to come through the speakers when turned on... its worth a shot
        Custom interior...
        TEAM NoVa
          Try one of these on the power feeding the WB O2.
          http://www.msdignition.com/Products/...,_26_Kufd.aspx
