Anyone have any ideas why the dash lights would suddenly stop working? I checked the fuses the instruction manual listed for the instrument cluster and they seem to still be good. Are there any other fuses I can check?
Make sure the dimmer isn't all the way down :P. Do you have power windows? If so, do they work? If not, it could be a BCM problem. If they do work, then it's probably a bad ground somewhere; there's one under the driver's side kick panel, I think one under the center console under the ashtray area. that's all I can remember ATM.
