wiper issue - FirebirdV6.com/CamaroV6.com Message Board
wiper issue
  • wiper issue
    out of no where, when i turn my wipers OFF, they stop in the vertical position ( straight up and down in my face)
    wipers never had any issues before, any ideas?
    Re: wiper issue
    maybe switch?? have you googled it?
    Team NoVa
      Re: wiper issue
      i think that there is a gear in there, and if it becomes mis adjusted your wipers will do that.. i will try and find more info
        Re: wiper issue
        i know there is many threads about this on ls1tech but their search still sucks, but this is what i found:
        "On some GM vehicles, if the wiper return detent gets bent slightly out of shape, the motors will stop in the upright position, not the down position. Happened on my wife's Montana minivan. I bent a little tab in the mechanism using a hammer and chisel, and that fixed it. We're talking less than 1/16" here."
          Re: wiper issue
          alright, i guess ill just take some of the coloum apart and see whats up then. thanks alot.
            Re: wiper issue
            Do not take the column (or "coloum") apart. Take the wiper motor housing apart to find the tab.
              Re: wiper issue
              happend to me before. there is a tab on your w.w. motor disk that has popped out or got spun around the wrong way.
              your best bet? buy a used motor for 30$ on ebay, take off your cowl, and toss in the new one. it's not worth trying to "fix" the problem. i'm speaking from experience.
              it will take 2 hours to replace tops.
                Re: wiper issue
                sweet, thanks will do. appreciate it man.
