quick q on Fuse Block Ignition/Ignition Power - FirebirdV6.com/CamaroV6.com Message Board
  • quick q on Fuse Block Ignition/Ignition Power
    Ok, I've got my LS1 in my 93 Camaro (removed the v6) and I'm wiring up the engine with a Painless wiring kit. I'm pretty sure I have most of the wiring down with it, but in the Painless instructions, under Dash Section Connections, it says that the PINK WIRE, labeled Fuse Block Ignition, needs to connect to Ignition Power.
    In my Haynes wiring diagram, at the top, it shows the #11 Fuse in the Underhood Electrical Center. This wire is also PINK and is called IGNITION. I am assuming this is where I splice the Fuse Block Ignition wire from the Painless kit to, but I just want to make sure before I do this. Am I correct in assuming that this is where I should splice into? Here's the diagram:
    Thanks for any help!
    5 days ago
