Interior Lights Wont Dim - FirebirdV6.com/CamaroV6.com Message Board
  • Interior Lights Wont Dim
    When I turn the dimmer wheel in my 97 camaro the lights wont dim :mad: and i have checked all the fuses!!!
    Re: Interior Lights Wont Dim
    But they still light up like usual? Chances are the dimmer switch is dying on you.
    1996 Chevrolet Camaro
    1995 Buick Park Avenue Ultra
    --Appearance Moderator--
      oh yea they light up just fine and I have a 1996 I use for parts and just plugged in the switch from the 96 and it still wouldn't work but it worked on the 96' and I noticed it didnt work after installed new deck if that helps
        That should tell you something is wrong with how you have the deck wired.
          i agree
          IIRC there is a dimmer wire back there to dim the lights on the radio.. im betting something happened with it, or it is disconnected and not letting the lights dim anymore
            well the harness for the radio which I thought was strange didnt include a prong to dim my radio automatically, and cam98aro where is this IIRC dimmer where is it so i can check to see if its been disconnected
              oh and a ? not to do with this how do you get your car as an avatar and on all your post
                Become a supporter.
                  Do you have LEDs in your cluster? LEDs won't dim....
                  ~97 3.8L V6 Camaro~
                  A few things
                  Only Member of Team Hooker?!?
                    nope everything is stock
                      Become a supporter.
                      and how to i do that lol
                        http://forum.camarov6.com/announcement.php?f=20&a=4
                          Thanks!!
                            ok so i know its been a year but i have finally fixed the problem lol im slow plus it wasnt a huge concern but incase other ppl are having this problem it was the brown wire/ dimmer wire going to the radio harness well if your radio is an LCD screen or if your radio has a dimmer option in the settings menu it will not dim with the lights so make sure u yank that brown wire out of the harness and everything will work just fine kinda strange lol
