Power window problem - FirebirdV6.com/CamaroV6.com Message Board
  • Power window problem
    I have a 1995 Firebird. The power windows have quit working. The fuses and relays appear to be ok. I've checked the switches for continuity and they are ok. I have juice from the switches to the motor. So I bought a new motor. Still doesn't work. I wired the motors direct and they don't work not even the new one. Would appreciate any ideas on what to do next. Thanks
    Re: Power window problem
    Maybe got a dud motor...
      If youve tested them directly to the battery, then Id agree with dgreet77
        possible dud...did you check for power at the motor?
        Team NoVa
          yes there's power at the motor
            is it both windows? if it's only one, it could be the window regulator instead of the motor. if it locks up, won't matter how much power is going to the motor....
