I keep blowing the turn signal fuse. I've tried changing the flasher relay, but that didn't help. My hazards work, but on the rear lights. When I turn on the hazards, the turn signals atleast light up and flash on/off where as the turn signals wont unless i change the fuse. When I do so, they last for about 10 minutes then blow. I've looked in the older threads, but I'm not seeing a situation similar to mine. Any suggestions??
Weird problem with turn signals
Re: Weird problem with turn signals
well i went to replace the bulbs as a last ditch effort, and long and behold, my right turn signal was out of its socket with no light bulb in it! replaced the bulb and everything works now. I did however blow another fuse, but i replaced and its holding up for now.
Should be a flasher fuse too in there you can check , either that or a short somewhere.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
