ok so i got a 2000 camaro 3.8l auto. i did a coolant flush and chagne this weekend and while doing so my father and i noticed that my fans werent working. anyways i went ahead and changed the 3 fan relays and check both the 40 amp and 10 amp fuses both of which were fine. well today i went and tested the terminals on the fans and got nothing. my father said he thinks it might be the thermostat for the fans that went. however neither of us know exsactly were to locate it and dont want to strip all the wiring to find it. anyone have any idea were it is located.
cooling fan help again.
Re: cooling fan help again.
I dont know what the stock fan settings are for 2000, but my 96' was set to kick on the low fans at 225. If you take a test light and clip it to something metal like usual then bump the relay terminal it should kick on when grounded. You probably just need a tune or a manual fan switch.
If you turn your A/C on the low fans should get on. One way to test them.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...1 week ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....3 weeks ago
