Turbo pippping pic - FirebirdV6.com/CamaroV6.com Message Board
Turbo pippping pic
  • Turbo pippping pic
    Was at the exhaust shop yesterday, had them install my resonator (looks like a big CAT, 7"s long 6"'s round) with a 3" V-band on it and made the rest of my system so it can be taken off and put back on if I need to take the turbo off for something. Fabbed up my turbo Y pipe 2.5's with flanges going to the headers and the other end is the 3" oval. It sits next to the oil pan and the oil pan is 1/2"'s lower so I should be good for clearance. They also welded my wastegate to my turbo pipe and welded a 3" v band that will be used on the downpipe. I spent today spraying them down with 2000 degree paint about 4-5 coats, ran in some spots but atleast it will be coated well.LOL I'll post a pic of them and a link to what resonator I used, sounds outstanding with it no rasp at all really mellow.
    http://cgi.ebay.com/ebaymotors/THE-S...item45ee738a76
    Re: Turbo pippping pic
    Nice. I know you were aiming for 400RWHP at 12 PSI right? I know you're running forged pistons but is there anything done to the top end?
    Edit: Whats your estimated price for all the fabrication pipes?
      Right now polished TB, 36lb injectors , slightly polished intakes heads, VS cam , 105 LB springs, modded retainers, and 5/16 pushrods. My spare set is P/P intakes, P/P heads new stock valves& 3 angle valve job/milled, 130lb springs, modded retainers, Comp oem lifters comp locks, comp .105 pushrods, double roller timing chain, Oil PSI kit, MLS gaskets, lower alm. gaskets and 65lb injectors.
      I think the total charge will be about $400-$500 to cut weld the pipes up, I paid $200 this last time for them doing what they did , I really think I'm going behind the axle when I go back with my old Dynomax 3" in/out muffler.
        how did you do a single turbo?
          Re: Turbo piping pic
          Just use a set up like this under the K or forward facing headers. The pics are from Teful Huydens turbo setup with a GT40R ,with a notched K member. My setup is a TUb. K member with 3" oval piping = 2 1/4" height, which doesn't come past the oil pan in height so it shouldn't hit anything I hope. I hope to be done with the hot side in a week or 2 and start on the rest again.
            i think im gonna go with under k setup, ffh seem like too much of a hassle
              look forward to seeing this in person when its all completed
                You'll be more than seeing it , you'll be driving it at the track, since you way less than me.LOL I still have alot to do before getting it ready, I have decided to install the 65lb injectors instead of seeing if the 36lb injectors would hold up. Better to be safe than sorry. I still need to install the methanol kit in also even though it's winter I would like the extra security. Still have along time to getting completed since I don't have a full time garage anymore.
                  what happend to me driving it???
                  Team NoVa
                    I forgot , your 130lb @ss can drive it,LOL but if you can't make it down Meatyshells is going in the seat.
                      ill be the test driver when u finish to make sure it doesnt blow up :P
                        I hope nothing blows up, $1600 turbo not to be messing around with.
                          im excited now :D
                            but if it does, wouldnt u rather it blow me up than u? :p
                              Originally posted by venom3300 View Post
                              but if it does, wouldnt u rather blow me than u? :p
                              hahaha, what a ***
                              Team NoVa
