Alright, time for some setup ideas... - FirebirdV6.com/CamaroV6.com Message Board
  • Alright, time for some setup ideas...
    It's me again, 2002 Pontiac Firebird.
    I've gotten ALOT of information regarding supercharging, turbo'ing, or a motor swap for my Firebird but I'm still at a point where I can't make a decision on what I want... So lets go ahead and spill some more beans and show my setup plans and see what kind of advice I can get based on those... First the primitives... what the car will be used for...
    PRIMARY OBJECTIVE AND CONDITIONS
    Whatever I decide to do, the car will need to remain VERY streetable. I purchased the car about 6 months ago, it had 82,000 miles on the clock. I just crossed over 100,000 miles about 2 days ago. Means I put 18k on her in the matter of 6 months and predicting atleast 36,000 miles per year. I do ALOT of driving. Some of it highway, some of it in the streets. MOST of the time it doesn't really see Rush Hour or stop and go traffic, but at times I do get stuck in it so my ideal setup would need to be friendly in these conditions. I am also located in Georgia and it gets hot and pretty humid in the summer time. It's not as bad as Arizona as far as heat or humid as Florida, but the combination makes even my stock car drive sluggishly. I definately need a setup WITHOUT methanol that could sustain temperatures of over 115 degrees of heat and humidity while stuck in traffic and using the air conditioner. I need to retain atleast 22 MPG combo highway/street. It WILL be taking long road trips in the future, but these are mostly highway miles. If I supercharge it or turbocharge it, I still need the motor to last atleast another 100,000 miles without internal damage occuring.
    GOAL
    To have a MOSTLY street car, rarely strip car with a Forced Induction V6 OR V8 putting down ATLEAST 350 RWHP, preferably 400 RELIABLY on a considerble budget. I might have to divide the project up into two segments as the money for it arrives, but when it does arrive I want a clear perspective of what I'm going to do. I can't spend more than $5k on the car and honestly, PREFERABLY I'd like to stay around $3,500 and I'd like to reduce that to even $2,500 but I know thats going to be very hard.
    OPTION 1 - SUPER CHARGER VIA PROCHARGER
    I know there was a company that used to make a kit for our cars. I wanted to know when they made it, how much did it cost? I also know there is an LT1 kit that would also fit our cars with some modification, but what kind of modification is necessary to perform this? Now my questions...
    1. How much boost with the ProCharger S/C will I need to get my desired power level?
    2. What klind of supporting motor mods will I need to attain that power level and sustain it RELIABLY?
    My ideal setup was this...
    GTP Shortblock from Ebay OR Forged Pistons from ZZP
    L32 Coated Rods from ZZP
    P&P Heads & Lower/Upper Intake from ZZP
    Mild to Moderate cam from ZZP, TSP, or Comp Cams
    3,000 Stall Converter
    Electric Water Pump from ZZP
    Procharger - can get used for $1,800, freshly rebuilt too.
    BOV - Ebay
    Intercooler - Ebay
    Alluminum Radiator - Ebay
    Transmission Cooler - Ebay
    Now what if I divided those into stages?
    For example the GTP Shortblock and Procharger W/ Intercooler in Stage 1
    The Heads/Cam, Stall Converter in Stage 2?
    The Alluminum Radiator and Trans cooler in Stage 3?
    3. How much will it cost to fabricate a ProCharger into the 3.8L V6?
    4. At 10 PSI or greater, will this setup be a reliable STREET DRIVABLE CAR? If not, what changes would you make or what setup would you biuld?
    5. What kind of intercooler should I run, aswell and BOV?
    OPTION 2 - TURBO
    Alot of people go this route because it's much more efficient and honestly I don't blame them. While I'm a bit of a person who likes to be different however. I honestly like the Supercharger more than I do the turbo charger because I don't like the idea of having exaust pipes clearly visable infront of the engine. So yes, looks are also important. However if we're talking a signifficant difference in price for the same or greater performance, I can comprimise.
    First thing is first, I know turbo's are a bit different than Superchargers and have this thing called ".ar ratings" and I have a slight clue as to what they mean, I believe the lower the number, the sooner they begin boosting, and something around .68 is good for our cars IIRC, but if I'm wrong I'm willing to stand corrected. I believe T3 and T4 Turbo's are good for our cars...
    http://cgi.ebay.com/ebaymotors/t3-70...Q5fAccessories
    What do you think of that?
    Stage I would include
    Forged Pistons or a GTP Block
    T3/T4 Turbo setup @ 15 PSI W/Ceramic Coated Piping
    BOV
    Wastegate
    Intercooler
    Stage II would include...
    P&P Heads, Lower and Upper Intake and Throttlebody.
    Cam
    3,200 Stall
    Transmission Cooler
    Oil Cooler
    Alluminum Radiator
    Manual Fan Switch.
    Now for some more technical questions, What kind of BOV, Wastegate, and Intercooler should I use? Also what about for the procharger?
    OPTION 3 - LQ4 6.0L Motor Swap vs 5.3L Motor Swap
    Story behind this is, a local mechanic will do all the labor involved for $700 if I buy his 5.3L motor for $900... and will do the LQ4 for $850 and I can get the LQ4 in for about $700... Im leaning toward the LQ4 but I have options for both.
    With the LQ4 I will leave it the stock displacement. Swap the heads out for Alluminum 5.3L heads to reduce weight and improve power. Long tube headers and True dual exhaust w/high flow bullet cats.
    Stage I
    Lid - $80
    Full Exhaust - $600
    LQ4 Motor - $700
    5.3L Heads - $400??
    BBK Intake W/Corvette Fuel Rails for the return lines to the fuel tank. - $500
    Rebiult A4 Trans - $900
    Stage II would be to build those heads and add a Futral F14 Cam, biuld the tranny and replace the 10 bolt with a 12 bolt
    I also know the harness needs to be changed aswell as front suspension and sway bars.
    The 5.3L would be the same as the Stage I LQ4 except in Stage II I will be stroking it to a Forged 383 and possibly adding a procharger.
    Any more input, ideas, suggestions? I'm having a hard time trying to decide which one I want to go with.
    Re: Alright, time for some setup ideas...
    I would vote for option 2, but to upgrade your heads/cam before you touch anything on the bottom end. Our bottom ends are pretty stout, and you would see a larger increase from the top end products.
    Car expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
      i am in the process of doing the option 2 right now, i have a tial 38mm wastegate and a greddy blow off valve, and hopefully i can pick up a .68 from a member on the boards, im most likely going to go with a ebay intercooler,
        cxracing makes a good intercooler, ssms has a nice t70 up for sale i bbelieve
          I say option #2. My next project I will start next year will be a 08' L26 block 1200 miles and will use JE 9.9:1 forged pistons ,clev. 77 bearings, comp OE lifters ,comp .105 pushrods, P&P heads with 130LB springs, MLS gaskets, ARP head studs , P/P intakes, double roller timing chain ,Oil PSI kit, 65lb injectors and will most likely stick with the VS cam unless I find something better I like. Will be built for a little over $2000, then will look into a Performbuilt tranny for $2300, Should handle some good boost 400-450 at the wheels with 12 PSI-15 PSI. Then only thing need to watch for is a rearend which a 9" will cost about $2000. Plus there is more room under the hood to actually work on the 3.8 which I like.
            Option 2. If you're worried about how the exhaust pipes will look in your engine bay, get stainless. Hah
            Actually, option 4 is best. Give your money to me. I'll build my car up more and let you drive it every once in awhile. Win win right?
            TEAM C6V6
              i already have dibs on it!
                Cool, I was going to say I was upgrading the bottom end so it could handle more boost. To attain 350 - 400 RWHP. Will the stock pistons be able to handle more than 10 PSI on a good tune?
                I was wondering would an Air to Water intercooler be any good and how does an Air to Water intercooler work? Do I have to fill it up with water or something?
                Thats an amazing deal for $2,000 - Who's doing your heads and will you beable to do all the labor yourself or how is that working? Where are you getting all the motor parts?
                Also - what do you think of this motor / price?
                http://cgi.ebay.com/ebaymotors/2005-...Q5fAccessories
                If I were to build it instead and put the heads/cam in it and drop it in? or should my motor be fine?
                How much more will stainless cost me?
                Option 5 - I give you my money, you sell your car, use money toward helping me build my car into the fastest machine on CamaroV6.com, and I'll let you have dibs on the car, from the back seat! :) joking joking...
                  yes the stock pistons will hold, there are people running 22psi on completely stock motor
                    linx I think put down an insane amount on a stock motor, with very fine tuning. It's all about what parts and hwo you tune. the tune is the biggest aprt
                      Who is running 22psi on a completely stock motor? From what I remember people were only pushing 12psi on a stock motor. I'd really like to know since I'm installing a boost controller of sorts here shortly.
                      TEAM C6V6
                        TurningFast on FTV6 is running 20+ psi on stock guts.
                        http://www.fquick.com/garages/Pontia...ird/1998/4254/
                        1997 Camaro RS A4
                        2006 Chevy Colorado
                        2003 Kawasaki Ninja ZX6-R
                          Wow... Just wondering but don't you think 20+ PSI should at least be in the low 11's? He still seems to be in the LS1 territory, of course I know he's running stock drive train and he might not be getting any kind of traction either though.
                          I am going to get a heads/cam setup for it too though...
                          I have 0 experience btw working internal engine. I have done bolton stuff, water pumps, pulleys, full tuneups, but I'm kinda afraid of pulling off heads or cam... Should I try to do it myself anyway or what?
                            What makes you say that?
                            LS1 territory?? What does that mean? There are LS1's that run single digits and some that run 14's.
                            He's pulling 1.6 short times...Im sure he's getting plenty of traction.
                            1997 Camaro RS A4
                            2006 Chevy Colorado
                              Well blow me down. I am a bit confuzzled. At 7ish psi I was pulling off high 13's. That's with the open rear end and 3.08 gears. I would totally expect 20 some psi to reach 11's. Oh look.. hmm he did. I wonder if that was after he put the 3.42's in. Maybe I just don't know enough.
                              TEAM C6V6
