Intercooler Options for Firebird - FirebirdV6.com/CamaroV6.com Message Board
  • Intercooler Options for Firebird
    I have an 2002 Pontiac Firebird and prepping a turbo or s/c setup... either way I want to run an intercooler, however; I've come to realise that if I mount an Air/Air IC on my car, it wont get enough air to be of any use because there's no grille. I don't want to cut the bird emblem out of my car or make any cosmetic body modifications. What are my options? I was thinking of an Air/Water intercooler but dont they require a additional radiator? How do those work?
    1997 Camaro RS W/T-Tops<br />All Stock / 200 HP
    Re: Intercooler Options for Firebird
    Air to water will take up space and cost 2-3 times more, I would just do front mount there are pictures around of setups. Thats just my opinon though.
      Just get a small Air to Air and mount it like Blizzard did. That kit was set up horozontally infront of the guard peice under the car. Just make sure you dont overdue it with the boost, from what i understand those 26/7/3 in intercoolers arent supposed to take more than like 400hp or sumthin.
        I used to have a picture down there. :/
        But.. this will help a lil I suppose.
        http://www.fquick.com/garages/viewga...wimg&id=137088
        I know it looks ungodly low in that pic but it's not bad. Check out my other pics where the car is actually on the ground.
        TEAM C6V6
          blizzard delete your message so i can pm you lol, pm me when you deleted some,
          also i ordered a air to air for my car, 32x12x3, gonna mount it behind the front bumper
            Fondle , that intercooler will fit right in between the frame rails up front after you remove the front bumper support. Mine did and its 33 X 12 X 4, I did have to grind alittle on mine now that I remember.
              well i have a 99, its a littler different front end, so hopefully it wont be too much fabbing
                Frame will be the same ,since its the same platform.
                  alright good to know, where did you drill into to bolt it down?
                    From the top , you'll see how it goes.
                      hey blizzy is your maro dropped any?
                        it appears to be lowered quite a bit in the pictures, but im not for sure
                          there is a set up that uses 2 small intercoolers mounted flat in both front corners but cant remember who makes it.
                          1999 Camaro V6 A4<br />Navy Blue metallic<br />Intake+Exhaust+4.10+?=?
                            Stock springs on mine. But I swear the damn thing drives and feels lowered. Sits lower than my other car too.. So that's why I'm confused as well. Worn springs? eh.
                            TEAM C6V6
                              You guys rock, true gearheads...
