So im planing on putting a m90 supercharger on my 97 firebird (read before you flame) - FirebirdV6.com/CamaroV6.com Message Board
  • So im planing on putting a m90 supercharger on my 97 firebird (read before you flame)
    "Top Swap"
    Ok, so despite all the hardships people have said about this swap i'm going to give it a shot. i found a great deal for the whole l67 motor from a wrecked GTP so i'm going to follow through on this project. I also plan on taking lots of pictures and hopefully if im successful make a guide on how to do the swap.
    Im getting the motor on Sunday so once i get it i am 100% going to follow through with the swap.
    it seams pretty straight forward but im sure once i get the motor ill think of alot more problems that im going to run into
    i plan on doing something like this to the SC to make it fit... i know its hard
    http://www.3800pro.com/forum/rear-wh...nly-picts.html
    So far this is what i concluded i needed (if i miss something please let me know)
    M90 Supercharger
    L67 idler pullies
    L67 belt tensioner
    L67 throttle body
    33# injectors
    L67 crank pulley
    L67 MAP sensor
    L67 heads
    L67 LIM
    L67 Valve Covers
    L67 fuel rail
    Head Bolts
    Rocker Bolts
    S/C Bolts
    LIM Bolts
    L36 to L67 wiring harness adapter kit or the l67 harness
    Vac lines
    Coil pack bracket from a 97-98 GT/GTP
    S/C belt
    Re: So im planing on putting a m90 supercharger on my 97 firebird (read before you fl
    dude that'd be sick if you think you can do it. It would probably be easier to turbo it but it's always cool to fight the power and be different.
    auto, aluminum driveshaft, Fast Toys Ram Air, !air silencer, smoothed lid, Pacesetter shorties, 2 1/2" exhaust, !cat
    New Time:
    15.11@91.14
    Team 3M Mafia
    New Times coming soon
      I would suggest you get a hold of Merlin and talk to him before you jump into this. He can give you some good tips and info, a lot more than just what a thread says or shows. While it doesn't look like a lot of big work, there are a lot of little things that need to be addressed and changed. You'll also need some form of tuning to get the car running with the m90 and your stock PCM.
      Edit: Looking through that list, I don't believe the L67 TB will work. Merlin used an LT1 TB on his setup. You'll also need to reroute the heater hoses if you plan on routing the intake out on the passenger side. An additional FYI... the '97 L67 is different from the 98-03 motors. Vacuum lines and coolant ports differed between those years and are not interchangeable.
      '99 Camaro
      '04 Saab 9-3 Aero
      '90 Audi Coupe Quattro
        M90 Supercharger
        L67 idler pullies
        L67 belt tensioner
        L67 throttle body
        33# injectors
        L67 crank pulley
        L67 MAP sensor
        L67 heads
        L67 LIM
        L67 Valve Covers
        L67 fuel rail
        Head Bolts
        Rocker Bolts
        S/C Bolts
        LIM Bolts
        Vac lines
        S/C belt
        If you got the whole motor then why not just swap the motor and injectors and purchase a centrifugal kit. It would probably be alot easier. I personally wish that a comany make a LIM adapter to make the GTP supercharger work with RWD 3800s. Good luch with the project!
          im a little confused by this can you explain? how it will affect me?
            in a nutshell this is my plan...
            using my block/ pistons etc,
            i want to swap to heads from the l67, LIM l67, SC (Upper intake)
            from what i have researched these parts should work with my 97 firebird 3.8l correct? (after i mod the SC)
              I dont know why you would want to keep your L36 pistons as opposed to using the L67 pistons which are lower compression and overall better for boost
              1997 Camaro RS A4
              2006 Chevy Colorado
              2003 Kawasaki Ninja ZX6-R
                actually the gp guys are using the l36 bottom ends in there builds lately. Even zzp used a l36 bottom end in their shop car that went 9s
                http://www.bowtiev6.com/
                  cause that u get the higher compression w/ boost. that way its not dog w/ the boost
                    Really? Thats the first I've heard of that.
                    I'd prefer lower compression to run higher amounts of boost, but since the OP is using an M90 its probably too weak to much more than 10-11 psi so I guess higher compression would be better for lack of more available boost.
                    Scrap it and get a turbo kit ;) (JK)
                    Are you doing a cam swap too? You may as well if the motor is pulled out and accessible (IMO).
                    Im interested to see how this works out. Good luck! :tup:
                    1997 Camaro RS A4
                    2006 Chevy Colorado
                      i already have the gt1 cam
                        they make cams specifically for forced induction! ;)
                        New Time:
                        15.11@91.14
                        Team 3M Mafia
