Thought I would show some pics of the -10an oil return line I just drilled and used washers and GM black sealant to seal everything up. Didn't want to weld it since it was easier to use sealant and nuts, washers and sealant. Also was great to have the pan off becuase I had to trim down the oil gasket valley, so the inside of the -10an return bolt didn't hit the plastic. Also modified the oil gasket so when we installed the new oil pickup the pan could go almost straight in instead of pulling it down and trying to get it at a certian angle. Also threw in some QA-1 shots of the rear ones and a close up of one of the fronts installed.
Pics of -10 return line
Re: Pics of -10 return line
looks like good work steve, maybe ill get stationed close to you and i can come help do some work???Team NoVa
Thanks, only base close is Luke Air Force Base though, That would be cool. I (well me and Meatyshells )LOL should have it done in a few weeks, he's going to help me get the turbo pipes on and go from there. I have a spare set of heads going to be redone with manley valves also going to buy a L26 engine here soon to start building it up.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by Pewter02Camaro View PostLooks nice and clean, good job!08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by Mighty Thor View PostIt looks nice Steve. Did you have to remove the oil pan? Or did you just drill it there and catch the debri with a magnet and then empty the oil?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Cover what cover? I don't need no stinking cover LOL J/K I am missing 25% of my brain.LOL Just used the plastic covers that came with the hoses to protect the threads, I used blue thread locker at the oil pan connection even though it was a AN connection , I didn't want vibration to have it come loose. I bought enough line so it is all the way up to the brake booster, so I will have to take a 18" line out or 2 when the turbo goes in so I don't have alot of slack. Also don't have to worry about oil coming out since its not pressurized and above the pan gasket.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by N2OEQIP View Postnot knocking ya but having Nuts in your oil pan is not a good thing. Granted ya said its locktited on there.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
