Just started getting some clearance on my oil filter neck for my PD. And what do you know ground right through it. F*** my life.
Oil Neck
Re: Oil Neck
JB weld it, you'll be fine.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Oil Neck
I would think it would be around 60 PSI+ and maybe lower when warmed up, since that what the oil pressure is at on most F-bodies.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Oil Neck
I would just JB weld it, so you don't have to file it down anymore becuase you can just use alittle JB weld on it to stop the leak.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Oil Neck
Originally posted by Watazz View Postdo you think if i had the hole arc welded it would F*** up the clearance for the belt? Its an extremely small hole. hardly even there.
