So i installed the powerdyne tonight and started it. It screams really loudly at start up, then goes away. Then if i rev it it screams. Come to fin out it is the A/C, and if i turn the A/C on it screams all the time. Has anyone else had this issue and know how it fix it?
PD problem
Re: PD problem
Originally posted by Watazz View PostSo i installed the powerdyne tonight and started it. It screams really loudly at start up, then goes away. Then if i rev it it screams. Come to fin out it is the A/C, and if i turn the A/C on it screams all the time. Has anyone else had this issue and know how it fix it?
Also, make sure that the pulley from your AC is well connected to the belt.
Re: PD problem
Thats a overtightened belt which will in time will bend the input shaft. When tighten the belt from the ALT. to the power steering should have about a 1" play or about a 90 degree twist on it. If you can't twist the belt in that section 90 degrees or can't push about a 1" downward then its over tightened. When I had mine and replaced mine input shaft once becuase the teeth got meesed up when the internal belt broke and I had to cut it off the input and output shaft I nick the teeth so when I replaced the input shaft it was bent/ warped from the tension of the belt on the pulley , so you have to watchout for it. This only happened when I was going with 2.8, 2.6, 2.25" pulleys. Just trying to get more PSI. If I would of stuck with a 3.12 it would of lasted alot longer.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: PD problem
runs fine considering i dont have a discharge tube yet haha. I got the gauges mostly done tonight so i will hopefully get to working on some kind of discharge tubing soon. Probably go with some stuff from Siliconeintakes.com
Re: PD problem
I think they make a 103.5 and a 103" belt also, a BOV would be nice for it, a ran a Trbo XS bov, blue one I think was good for up to 15 PSI , ran like 2 spacers in it. Is it a stock pulley size ? Did you go with a ASP racing pulley?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: PD problem
Originally posted by ssms5411 View PostI think they make a 103.5 and a 103" belt also, a BOV would be nice for it, a ran a Trbo XS bov, blue one I think was good for up to 15 PSI , ran like 2 spacers in it. Is it a stock pulley size ? Did you go with a ASP racing pulley?
Re: PD problem
Oh i and i got my gauges hooked up today. I will post some pics once i get the adapter for the fuel rail to the sending unit. The boost is the only one i got hooked up with power. Gauges from prosport, I love the way they look. Good cheap buy.
Re: PD problem
3.05" is fine, Thor is running my old 2.8 or 2.9" pulley , I know if you run a 2.6 you can use a 103" belt. And the 2.8 was the 103.5" I think. Just don't go crazy like I did wanting 10-12LBS of boost and running smaller pullies they will eat up the internal Powerdyne belt and cause the bearings to go out quicker. I ran the stock pulley for 2 years and never had a problem, until I started dropping pulleys. If you want more power add nitrous.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: PD problem
Originally posted by ssms5411 View Post3.05" is fine, Thor is running my old 2.8 or 2.9" pulley , I know if you run a 2.6 you can use a 103" belt. And the 2.8 was the 103.5" I think. Just don't go crazy like I did wanting 10-12LBS of boost and running smaller pullies they will eat up the internal Powerdyne belt and cause the bearings to go out quicker. I ran the stock pulley for 2 years and never had a problem, until I started dropping pulleys. If you want more power add nitrous.
