so long story short I got the fuel rail adapter from metco motorsports, and it must have had a bad thread. Spun it on with my fingers + two turns of the wrench = F***ing leaking. Anyone ever have a similar problem?
Metco rail adapter
Re: Metco rail adapter
Did you unscrew the pin inside of it and take it out of the fuel rail? Then use some paste or teflon tape on the threads so it help stops leaks. I have had my Autometer fuel sender and PSI gauge for almost 10 years with no problems.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
