I am have doing a lot of research and reading on the intercooler spray systems. I am not convinced it is worth the $300 to buy a complete setup off ebay or vendor but if I can make the project work for under $100 and net about 5-10 horsepower I would be happy. Meth injection is out of the question right now as I dont have access to HPT currently and I am turning the boost up to 18 pounds soon.
My plans are as follows:
Straight setup, nothing fancy, all mechanical.
CO2 tank, 2.5 lbs (Good for about 2-3 full runs at the track) - $30
Stainless Steel hose - Trying for $25
Fittings - $15
Mechanical on/off valve - $5
Copper tubing for sprayer - $10
Ill be looking for probably 200-300psi on the hose so nothing crazy. Current idea is to mount the tank on the driveshaft hump right between the 2 back seats. Have the hose run right inside the console with the valve in the ashtray spot. From there run the hose through the firewall and over to the intercooler. It will be stealth except for the tank in the backseat. I could put the tank in the rear jack well but am leaning towards the backseat. I will bend my own sprayer with copper tubing. 2-300psi on the copper tube with pinholes should be fine. I will block off any direct route to the K&N air filter on the turbo inlet.
Still in the concept stage.....Any thoughts?
Fittings - $15
