alright so what would you guys consider bad IAT's under hard boost?
Bad IAT's
Re: Bad IAT's
During the summer here I would have 220 degrees, thats why I only could run 8 degrees timing.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Bad IAT's
You should watch your IAT's they will tell you how efficient your intercooler is with the amount of timing. Like I'm running close to 20 degrees with the setup right now with no KR. But when you add methanol it will be behind the IAT and maf sensor so you won't be able to log and view it , just watch the KR to see that it is working. The 220 was with my PowerDyne and when I added a intercooler they went to 160 degrees but over stressed the internal belt and bearings.Last edited by ssms5411; 03-24-2011, 05:20 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
