How much boost can a stock 3.8 handle safetly. 120k miles so not really hoping for too much out of it. jw
How much boost?
Re: How much boost?
10 PSI is safe, aslong as you have supporting mods ,like Hptuners, wideband , 255 fuel pump , and injectors.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: How much boost?
Aslong as the tune is good and air/ fuel ratio is good with no KR , you should be good with 10 PSI. Your current motor being in good condtion with no leaks. Theres people running more than 10 PSI but I would say 10 PSI is safe.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: How much boost?
10+PSI aslong as you can tune it. I maxed my maf and PE at 10lbs.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: How much boost?
Originally posted by Blizzard242 View PostA lot of it depends on the turbo size. 10psi on one turbo isn't the same as 10psi on another. I still have trouble grasping this concept myself but I've heard it a lot.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: How much boost?
the bigger one would be a T70, I'm using a GT35R which has really quick boost response.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by Need4CamaroThe panel under the HVAC controls where the button is supposed to be is completely missing when I bought the car so I dont know if this car had TCS or...3 weeks ago
by Need4CamaroI was wondering, are these cars DBC or DBW?
If swapping in an LS motor (lets ignore the rest of the complexity of the swap), what would be...3 weeks ago
