New camaro build,rear mounted - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Re: New camaro build,rear mounted
    Originally posted by ssms5411 View Post
    Nice car you got there Travis.
    thinks
    • #17
      man well travis ima try to copy your turbo setup
      • #18
        so would a t3t4 or t4 turbo be better for me since i only wont to push 300 horses at the most and i would be putting it at 250 just for daily driver
        • #19
          and i have been thinking about doing a liquid to air under the hood with its own like fluid bin so i dont use collent from the engine
          • #20
            which of these turbos would be good for 250 to 300
            i the t7 might be to big
            t7
            http://www.cxracing.com/mm5/merchant...ory_Code=TRBT7
            here are some t3t4
            http://www.cxracing.com/mm5/merchant...ory_Code=TRBT4
            http://www.cxracing.com/mm5/merchant...gory_Code=T3T4
            • #21
              or
              http://www.cxracing.com/mm5/merchant...ry_Code=TRBT35
              • #22
                I would go with the GT35.
                • #23
                  is there a diffrence in the the two gt35 turbos above,does the anti surge make a diffrence
                  • #24
                    and ssms how did you raise your ride height i wont to do that to my car i mean my car sits lowwww and with a rear turbo that wont be good
                    • #25
                      but see the the gt35 are oil and water and i just wonts a oild cooled so what the next best
                      • #26
                        If your in hot weather, having water cooling is the best so the oil doesn't coke up in the turbo. I rasied my front with QA-1 adj. shocks, the rear I used qa-1 shocks with 1LE springs in the rear. Anti surge don't know might just search that one.
                        • #27
                          so it would be water cooled not oil cooled or how does it work
                          • #28
                            ok so i have it down to these two turbos
                            • #29
                              top one is t3 the bottom is gt35
                              • #30
                                every turbo uses oil....not so much as to cool as it needs it for a lubricant for the bearings. sounds like you need to do more googling
