New camaro build,rear mounted
Re: New camaro build,rear mounted
which of these turbos would be good for 250 to 300
i the t7 might be to big
t7
http://www.cxracing.com/mm5/merchant...ory_Code=TRBT7
here are some t3t4
http://www.cxracing.com/mm5/merchant...ory_Code=TRBT4
http://www.cxracing.com/mm5/merchant...gory_Code=T3T4
or
http://www.cxracing.com/mm5/merchant...ry_Code=TRBT35
I would go with the GT35.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
If your in hot weather, having water cooling is the best so the oil doesn't coke up in the turbo. I rasied my front with QA-1 adj. shocks, the rear I used qa-1 shocks with 1LE springs in the rear. Anti surge don't know might just search that one.Last edited by ssms5411; 06-05-2011, 10:35 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
ok so i have it down to these two turbos
