I think I may be getting some belt slip with my PD it doesnt really hit 6-7lbs until 4700-6000 RPM, usually see solid 4-5lbs at lower RPM. Is that the normal range for you guys running the PD
PD slip
Re: PD slip
Yeah i know i posted the same thing in the other thread...
Originally posted by Pewter02Camaro View PostBut im sure the cross cuts I machined into my pully helped a lot to.
Daily: '02 Black Yukon Denali
Toy: '06 Torrid Red GTO
Gone: Powerdyned '02 Pewter Camaro
Gone: '07 Charcoal Yamaha R6
Gone: Ex-wife, lol
Re: PD slip
Your always going to have alittle slip, also the grooves help out alot. Just be sure to get the steel pulley as I aid in the other thread alm. will warp under high heat.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: PD slip
Even with the JD wrap and Greenglows grooves there will always be some slips.
Our member here, OneEightSeven, claimed that he got several double sided serpentine belts from Superchargeronline.com at a cost of several hundred. That would definately help our slipping problems.
I requested for some pics of it and everything. I asked to buy one from him.
Re: PD slip
Actually the grooves provide more surface area. If you were to measure from one side of the pully to the other going into the valleys and going over the peaks of the grooves you actaully would see a longer distance than measuring stright across. Hence more surface area contact. If you want to teat this take a flat peice of paper 4 inches say. Now take a peice of pqper 8 inches wide. Fold it into an acordian. And squise it down to 4 inches across. Same width, more area. Get it?Daily: '02 Black Yukon Denali
Gone: Ex-wife, lol
Re: PD slip
@Pewter02Camaro,
There is more surface area, pewter02camaro is right. This is why almost all proper SC kits are ribbed, not flat like the bs powerdyne setup we get. I'll be selling my double sided belts with the kit, but I don't think I will sell the belts individually, since whoever gets the kit would probably like spare belts. I will start posting part-outs some time in January. My main focus for modding is going to be my G8 GT.
Proof:
http://i.imgur.com/GKnKZ.jpg
http://i.imgur.com/hVrZj.jpg
http://i.imgur.com/s5Zuf.jpg
103" double sided belts.
I was going to run the XB-1A big SC on it, but honestly the G8 just makes more sense as a project car.sigpic
