Say hello to the 3.5 grape. The 3500 is bolted to the 4l60e trans running off the stock ecm and the 3.4 liter 17lb stock injectors. Fuel and ignition is controlled by the perfect power smt6 unit and (1) 160lb fuel injector. The cam sensor lobe was modified to send the ecm the correct signal. The crankshaft sensor signal comes from a notched harmonic dampener. Some more tuning and tweeks are still needed but so far the car runs awesome.
Good by 3.4 grape of wrath
Re: Good by 3.4 grape of wrath
Looks awesome. Did you do a top end swap or use the whole 3500?1997 Chevrolet Camaro
L26, Pacesetter headers, SLP cai, Centerforce DF clutch, Pro 5.0 shifter, UMI short stick, 1le driveline, J&M 35mm front swaybar, UMI lca's/phb/sfc's, KYB AGX shocks, Hotchkis stb.
The accessories are from the 3.4 liter motor. Only minor wiring mods had to be done.
The starter wire and cable had to be moved to the other side of the block. The fuel injector wires were separated to reach the injectors. If your ever in Jersey your welcome to stop by.
I know I'm a little late but nice swap. Was the turbo setup swapped over from the 3.4 or built for this motor? As for fuel you're running 17lb injectors and an additional injector somewhere further upstream to compensate for boost?96 White M5 Camaro. Manual everything. Magnaflow cat, dynomax dual outlet axle back. Swapped to a disc rear with 3.42s and a torsen differential, kyb gr2 rear shocks, moog rear endlinks.
Originally posted by MegaHertz View PostI know I'm a little late but nice swap. Was the turbo setup swapped over from the 3.4 or built for this motor? As for fuel you're running 17lb injectors and an additional injector somewhere further upstream to compensate for boost?
Originally posted by 2.8 Bird View PostI always thought that the 3500 wasn't a push rod engine.
Aren't you the fastest 3.4 V6?
Good job on the swap. I would love to see what it can do.
