water meth check valve placement - FirebirdV6.com/CamaroV6.com Message Board
  • water meth check valve placement
    where in the water/meth line do you want the check valve. close to the nozzle or close to the pump.... ? or does it really matter?
    Re: water meth check valve placement
    I have mine close to the nozzle but I don't know if it really matters.
      it keeps fluid from being sucked out of the line into the intake, correct? it allows water to flow back through it also right? does vacuum or anything keep the fluid in the line, up to the checkvalve? i'm not too close to installing my kit, just planning some stuff out in my head.
        It's a one way flow valve. Once the line is pressurized the check valve holds the liquid in the line.
          alright so it need to be close to the nozzle so that there is no delay.
