Power - FirebirdV6.com/CamaroV6.com Message Board
Power
  • Power
    Any one know of if a Eaton M 90 supercharger will work on a 2002 3.8?
    Also does anyone know if ZZP heads will work on our 3.8's? Thnx Sean...
    Re: Power
    There's a bagillion threads on this. Straight swap? No. Modded? Yes. But it's a real PIA your better off doing a top swap from a gtp. Honestly it's not really worth it the m90 won't give you that much boost. The best heads for the 3.8 are by Abbott but very expensive might be cheaper to P&P the stockers. If you have the time and skill to put in the SC go for it but if your having a shop do it forget it you spend a crazy amount just to get maybe 50+/- HP. Cam would be ideal
      Re: Power
      Refer to the "stickies" in FORCED INDUCTION forum.
      Raven
        Re: Power
        It depends on the pulley size and tune you plan on doing. Plenty of GTP running in the 11 and low 11 with this SC.
          Re: Power
          Thnx all. I'm doing a cam as well...
