well as most of u guys know ive done na v6's turbocharged ( both single and twin ) v6's including a destroked 3.4 turbo ( 3.0L) that made tons of power but ate itself up on one trip to the engine dyno
time for a new and totally custom project, i just scored a great condition 4-71 blower on ebay for 134$'s minus the front drive and rear bearing cover
but right now im bidding on a crager drive setup for pretty dam cheap so hopefully i score that, if not i can buy all new pieces from dyersblowers pretty damn cheap
the plan is to use a stock manifold base and modify it to mount the blower.
not sure how im going to adapt the drive pulley, but i will have to convert the v6 over to a vbelt setup so i can use the 3 inch drive belt,luckily i wont be stuck with a serp setup or vbelt on the blower.
the drive im bidding on is a 3inch wide cog setup and if that dont fit they do make a 2 inch drive system
i have 2 options here single 4bbl carb which i dont want to do im going to more then likley use a megasquirt ecm and a 4bbl tb ontop the blower with 6 incjectors under the blower.
anyways just though id share my new project, this will be making its way into an 88 rs once its complete
and yes i will be overdriving the blower, i see far to many ppl with 6/8-71's on sb's and bb's that underive them just cause they want the looks.
my feeling is if ur going to do a blower makes some dam power with the thing
ill get some pics of the blower up soon as it gets delivered
