Counter-acting elevation, Turbo build
Re: Counter-acting elevation, Turbo build
True. I had trouble mounting my passenger side header because it would hit the hvac box :/
You might want to start taking measurements inside you engine bay. Also make sure to wrap all the exhaust stuff or else you'll experience a lot of heat under the hood
Originally posted by Docta View PostWhen you guys put in rebuilt motors (cam etc) what's your break in? What oil? And is it easier to pull the motor with harness, or leave harness in the car?
I just realized your not going into the bottom end of the engine. In that case I wouldn't worry too much about break-in. Just make a couple easy pulls and you should be ready to go. An early oil change wouldn't be a bad idea though.
Well as far as I know, I'm pulling from the top, leaving the harness in. Break in will follow the COMP recommended 2000-2500 for 20-25.
Day after tomorrow. And not the terrible movie.
Well that's probably not going to happen. Lol. Its out, new one all with new accessories on it, and ready to go in tomorrow. Only mishap was a bull**** ****ing chain, 1250lb work load that snapped and dropped my new motor 5 ft as I was trying to put it in! Shattered the oil filter adapter, and broke an engine mount. I'll grab pictures of those... all good now, nothing else damaged. Getting a new mount tomorrow.
