12 Injector 3500 Intake - FirebirdV6.com/CamaroV6.com Message Board
  • 12 Injector 3500 Intake
    I got rid of my 7th injector set up and will be fabricating a 12 injector intake for my turbo 3500 intake. The stock 6 injectors will remain in the original location and 6 will be mounted in the plenum pointed right at the intake runners. I can keep my SMT6 tuner to control the added injectors, since the SMT6 will support up to a maximum 6 injectors. Pictured is my drilling template I will be using to keep all the holes spaced evenly.
    Re: 12 Injector 3500 Intake
    Cool idea, what size injectors do you plan to run?
      To start I'm leaving the stock 17s in the lower and 24s up top. I also have a set of 48s I bought that I can install up top if needed.
        Drilled out holes and grinded to an oval shape to allow the bungs to go in on an angle.
          Here's the bung and injector installed.
            Is this better than getting bigger injectors?
              It has pros and cons. It's much easier to tune, there's no tuning problems with idle and cold start up as with bigger injectors. All I need to tune is for when I am in boost. The stock tune and emissions is still the same, no need to be concerned at inspection time. I can upgrade to larger injectors without removing the plenum. Using larger injectors is less complicated installing and removing and the stock location is better.
                Here's the injectors mounted in the plenum. Next I need to work on the fuel rails.
                I also deleted the egr mount and straightened out the neck of the plenum, which normally turns to the left.
                  Started drilling the fuel rails with the drilling template. I miss my bridgeport miller at times like this but some times you have to improvise.
                    After drilling all the pilot holes I used a pilot counterbore to finish the job.
                    Careful attention to squareness and depth checking when using my dewalt milling machine.
                      I'm impress. That's really creative.
                        Thanks.
                          Test fit of the fuel rails. Next will be the mounting posts and fuel line fittings.
                            It's close but it fits.
                              That's pretty awesome actually- now just replace those top injectors with nitrous jets :stp:
