Turbo came in the mail today, just an ebay kit. This is my first turbo build. I'll probly be asking lots of questions here...
Finally went turbo
Nice, on install you might need to wack the heater box to get the passenger side O2 to fit , mine went in about a 1”. Then you’ll have to move the power steering res. and I deleted my EGR so don’t know about that.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
my egr has been gone for a long time, lol. thinking about deleting the heater box all together , im in florida and never need the heat in this car anyway. how'd you set up your oil drain line ? did you go into the pan or something else ? i was thinking about the remote oil filter spacer from intense, i could just put a T fitting on the oil return line from a remote filter for the turbo oil drain. also, (dumb question here) do both the wastegate and BOV get a vacuum line from the manifold ?
Yeah I deleted my EGR in 2002. I ran a -10an line from the turbo to the pan. Right above the low oil sensor. You want at least a -10an line so you don’t have any oil backing up. Then just tee off the oil pressure sensor with a -4an line to the turbo. Yes Bov gets a line and if there is a top and bottom vac line on the wastegate , bottom vac. to manifold top stays open or you hook it to a boost controller for more boost.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostYeah I deleted my EGR in 2002. I ran a -10an line from the turbo to the pan. Right above the low oil sensor. You want at least a -10an line so you don’t have any oil backing up. Then just tee off the oil pressure sensor with a -4an line to the turbo. Yes Bov gets a line and if there is a top and bottom vac line on the wastegate , bottom vac. to manifold top stays open or you hook it to a boost controller for more boost.
and im assuming you removed the oil pan to drill the hole for the -10an fitting ?
All the wastegates I’ve seen have 2 vacuum ports top and side or bottom. Yes, the top vents off extra air, when you hook a boost controller to it , it regulates the air coming out so you get more boost. If you plug it or have it hook to a vac. line you’ll pretty much double the spring pressure so a 8 lb spring will be around 16lbs . Made that mistake in 2012 with my under K turbo.lol Yes , I have a tubular K so pan dropped right out.Last edited by ssms5411; 01-06-2023, 08:43 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Also since you have a straight TB , might have to get creative with the downpipe it’s very close on the angle TB so being straight might be a challenge. When they welded my downpipe up they had to cut up the downpipe I had to make it fit.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostAlso since you have a straight TB , might have to get creative with the downpipe it’s very close on the angle TB so being straight might be a challenge. When they welded my downpipe up they had to cut up the downpipe I had to make it fit.
Originally posted by ssms5411 View PostAll the wastegates I’ve seen have 2 vacuum ports top and side or bottom. Yes, the top vents off extra air, when you hook a boost controller to it , it regulates the air coming out so you get more boost. If you plug it or have it hook to a vac. line you’ll pretty much double the spring pressure so a 8 lb spring will be around 16lbs . Made that mistake in 2012 with my under K turbo.lol Yes , I have a tubular K so pan dropped right out.
I’ll look but I have to jack it up anyways to check some stuff , so I’ll snap some pics. Waiting for the weather to get better then I’ll do it. No garage so just depends on the weather.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Probably jack it up tomorrow and do some work and take some pics. What cam did you go with again? I forget.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
