Ok, can somebody give me a list of all the things needed to build a turbo set up good for about 13-15 lbs of boost, it would be greatly appreciated
List
intercooler, piping, turbo, fuel pump, (injecters or an fmu), boost gagues, blow off valve, wastegate, i would do pistons for that much boost also.
I dunno a whole lot, that seems like a bit much boost to be running that much constantly. Something internally will break i think. Im not the one to ask though.
Go read maximum boost by corky bell, i have not read it but i gurrentee the next person to post will tell you that. By the way your SOOOO much better off buying a FFF kit. If you need to ask what your going to need my guess is you will be incapable of building a kit yourself.
Goodluck though...Red 98 A4 Firebird<br />..its pretty..<br />- - - - - - - - - <br />6 Infinity 3-way speakers with Alpine deck and 720 watt Kenwood amp..
If you have to ask, you probably shouldn't be doing it yourself. Buy a kit.
Oh, and read Maximum Boost by Corky Bell. [img]tongue.gif[/img]Matt
1998 Mystic Teal Camaro M5
Originally posted by Cam:
ROFL, i sooo called it, we posted at like the same time...Matt
-Kevin<br /><a href=\"http://heinz.no-ip.com/Car%20Pics/IM000117.JPG\" target=\"_blank\"><b>\'96 White Camaro RS M5</b></a> <br />GTP Shortblock - T3/T4 -6psi Intercooled<br />Open Downpipe
Heres my list, its not completely up to date. This does not include an intercooler, just the piping for one.
http://www.gmv6.org/turbo.html92 S10 3800 A4(96)<br />1/4: 14.374 @ 92.25 w/ 1.976 60\'<br />Turbo and 12\'s Coming Soon!
Maxiumium boost has great instalation and build up tips mainly.
It dosen't go deep into turbo science.
TURBOCHARGERS
By Hugh MacInnes is a hard core turbo charger book made for those who want to kick a$$.
It dosen't have all the tips but more info on other things.
I say they go great together.
Things you will need to build a good turbo system, those books talked about ^above^, a plasma cutter, welder that can do stainless steel other grinding tools like a bench grinder, open shoe angle grinder, saws all, drill press and a lot more before you think about what turbo or waste gate.\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
