is there ever going to be a supercharger for the 3.4 - FirebirdV6.com/CamaroV6.com Message Board
  • is there ever going to be a supercharger for the 3.4
    just wondering
    eddy maclean
    no
    1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
      yes, the batman kit will be converted to fit the 3.4
      91 Eagle Talon Awd Turbo 5 speed FOR SALE 6000$<br />Looking for a Fiero GT<br /><a href=\"http://www.swdsm.net\" target=\"_blank\">www.swdsm.net</a>
        Why Supercharge? Just go Turbo like some of the 3.4 owners did.
          Yeah, right after '98 and down get programmers...
          1997 M5<br />Borla muffler, SLP CAI, 1le swaybars, B&M Ripper shifter, 3.42s, rear disks, 1 piece DS<br /><a href=\"http://webpages.acs.ttu.edu/jerosbor/index.htm\" target=\"_blank\">Pics of my car</a>
            I rarely ever post but, but i do check in on the 3.4 topics everyonce and awhile. I see some replys that the 3.4 kit will never be made. Thats not exactly true. You will probably never see a kit mass produced for the 3.4 due to the length of time GM used it in the 4th gen applications. However i am the proud owner of a Vortech supercharger and water to air aftercooler set up... custom made for the 3.4. It uses the vortech V1 S-Trim Blower, and aftercooler unit. I run a 2.50" pulley which spools 12-15 lbs of boost on my modified 3.4 . I also use a MSD DIS4 ignition system along with Accell coil packs, hand cut Accell 8.8mm 300+ series wire's and AC Delco rapid fire plugs. I also converted the 4L60 trans (its a non electronic valve bodied car due to it being a 93)over to a reverse patterned manual valve bodied trans, along with adding a one piece drive shaft and swapping rearends. The car runs a 7.5" 10 bolt rearend with disk brakes braided lines, and 3.42 gears. The engine itself has way to many mods to mention, but i can say it is about as internally modified as you can go.
            Anyways thats the story on atleast one 3.4 application, as for availability the turbos are showing up more and more. Superchargers though? if you want one........this would be the one. Everything down to the adjsutable billet holley fuel pressure regulator, FMU, fuel pumps, ignition setup.....everything retailing a hair over 5000+
            This car will out run my slightly modified 95TA by a substantial margin. Its enough to make me sick, yet at the same time smile with a grin the size of the 17's its rollin on.
            The car is legit, and the kit is legit. And every bolt on i've bought is going up for sale. I guarantee the craftsmanship to be better than any other 3.4 kits you've seen..(supercharger)...well....ya know there are alot of kits out there heh,heh. But really it is a great kit, the best of the best stuff. all parts included, guages, ignition, the hole nine yards, and i'm even going to label the parts and take photos of the stuff to ease the installation process.
            Serious inquire's only....and only offered to the V6 guys here first.
            i can be reached at 304-615-0518
            5000+ dollars in stuff.....used in great shape, yet depriciated in value.....BO starting above 2000......for the whole kit. Almost all packaging still intact. MSD unit less than 5 months old....used under 5000 miles.
            start the bidding twofast4nu@yahoo.com
            phone # 304-615-0518
            Nicholas Gale Lauer
            93 Vortech Supercharged and Water to Air Aftercooled 3.4L A4 Camaro.<p>With fully blueprinted WRP 3.4L V6, 4L60E with reverse pattern manual valve body, MSD DIS 4, Accell coil packs, accell 8.8mm wires, Holley adjustable fuel pressure regulator. Autometer Guages(trans temp, water temp, boost, pyrometer, A/F ratio....and a few others to come). Complete headers back exhaust system, adapted Edelbrock 3 point strut tower brace, 1 piece driveshaft, 01 TA wheels, 97 rear w/3.42\'s(3.73\'s on the way), disks, and posi. Rksport Ca-100 ground effects, Superwing, and Hammond louvers. Numerous other goodies to go.... and yes they go.<p>items on the \"to install list\" 24lb injectors, aftermarket Front and rear sway bar, Custom sub frame connectors, driveshaft safety loop, and boxed in trailing arms.<br /> Catch me next season if your in Ohio, or adjacent states.
              Not to be a jackass or anything, but for that price you could buy a LT1 and a Vortech supercharger kit. I like the concept of cheap turbo kits, simply because the price is SIGNIFICANTLY lower and gain arent far behind the super kit. I, personally, like superchargers better but seeing as they all cost a buttload I'm gonna have to hold off and be slow for a while. [img]smile.gif[/img]
              <b> \'95 Camaro 3.4L A4 <i>Rikku</i><br />AutoX - Drift - Street </b><br />\"Sideways is faster.\"
                batman's might be matched to fit the 3.4....IF and only IF - it is ever even made for the 3.8. Question is, who knows?
                Silver00
                2000 A4 BMS Firebird<br />MTI Clear Lid & Green Filter, BMR Boxed SFCs<br />SLP Ram-Air HO Hood, Corsa w/the bling bling tips, KVR Pads<br />Red Painted Calipers, BMR PHR<br />BMR LCA\'S, Hooker Longtubes and coated Y<br />Taylor Thundervolt Wires & NGK PLUGS<br />15\" Weld Prostars & Skinnies ;)<br />SLP Fan Switch/160 Thermo<br />Yank 3600 Extreme Converter<br />SPI1 Cam and 918s, 772s, and comp hardened pushrods, Shaner\'s S2 TB
                  check the for sale forum you'll be plesantly supprised
                  Turbocharged and intercooled.<br />17psi(oops), stock fuel pump, no FMU<br /> <a href=\"http://www.cardomain.com/id/phoenix64\" target=\"_blank\">http://www.cardomain.com/id/phoenix64</a> <br />Video: <a href=\"ftp://ftp.pfabrication.com\" target=\"_blank\">ftp://ftp.pfabrication.com</a> Assorted car ****: TurboCamaroFull.
                    <blockquote>quote:</font><hr>Originally posted by Brett Garret:
                    Not to be a jackass or anything, but for that price you could buy a LT1 and a Vortech supercharger kit. I like the concept of cheap turbo kits, simply because the price is SIGNIFICANTLY lower and gain arent far behind the super kit. I, personally, like superchargers better but seeing as they all cost a buttload I'm gonna have to hold off and be slow for a while. [img]smile.gif[/img] <hr></blockquote>
                    What the ****...
                    Buy an LT1 and trans and wiring harness and a blower kit for $2000? I don't ****ing think so. Don't be a troll towards someone selling their complete top of the line blower kit on this board. Jesus!!!!
                    Scott
                      There will be a turbo kit for the 3.4 soon enough.
                      2001 A4 Pewter 75th Anniversary W68 Firebird<br />1997 Dodge Ram Extended Cab 360 CID<br />1996 Ford Explorer V6<br /><i><b>Any number you can think of, I can think of one higher.</b></i><br /><a href=\"http://www.criesmusic.com\" target=\"_blank\">www.criesmusic.com</a><br /><a href=\"http://www.mp3.com/beneaththestage\" target=\"_blank\">www.mp3.com/beneaththestage</a><br /><a href=\"http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar6.jpg\" target=\"_blank\">http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar6.jpg</a><br /><a href=\"http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar4.jpg\" target=\"_blank\">http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar4.jpg</a><br />AIM: Guitarchitect201
                        Re: is there ever going to be a supercharger for the 3.4
                        5 years later no turbo kit for the 3.4 :(
                          http://www.force-fed-fabrications.com/index2.htm
                          There you go new guy. It's been around for almost 4 years now.
                          Welcome aboard.
                            hi toofastfornu, great to see someone else has some fury into their 3.4 !!! i am currently fabricating a SC kit using a vortech V9 g trim. can you send me some pics of your setup, as well as other info like what ratio fmu you used? I need tuning like megasquirt, how does ur car run with everything and miniumal tuning? I have a built 3.4 as well, and NA its snappy so I can't wait to push some more air into her.
                            Check it out http://www.sounddomain.com/ride/2442211/
                              dude the thread is older than dirt. as far as i know this dude is long gone
                              Follow me!
                              Or this
