Anyone know what the specs are for the FMU that is sold with the powerdyne kit. I was going to attempt to rebuild mine with the kit Powerdyne sells. It's an adjustable rebuild kit from 8:1 to 10:1. I'm assuming 10:1 supplies more fuel over the 8:1 correct?
FMU calibration setting for Powerdyne?
I don't know which one you need, but I do know the answer to the ratio numbers...
It's the extra psi added, for each lb of boost.
So the 10:1 will kick the fuel up 10psi for each lb of boost.\'98 A4 Camaro v6->v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
I am running 6:1- the manual says that your fuel should be between 60 and 70 psi at 6 psi of boost.
Seeing as that we idle at 45-50 psi, you need an increase of 10-20 psi over 6 boost psi. Playing it safe on the 70 side, that works out to somewhere between 3:1 and 4:1.
I didnt feel comfortable running 4:1, so I put in a little extra fuel (probably running rich with 6:1)All gone :(<br />Best ET ever: 14.3 (I think)<br />----------------------------<br />Check out my site for exhaust clips, burnouts, and pictures, and the supercharger throttle body mod.<br /><a href=\"http://www.geocities.com/net_addict/index.html\" target=\"_blank\">Click on the Firebird</a>
<blockquote>quote:</font><hr>Originally posted by Ironman24:
Anyone know what the specs are for the FMU that is sold with the powerdyne kit. I was going to attempt to rebuild mine with the kit Powerdyne sells. It's an adjustable rebuild kit from 8:1 to 10:1. I'm assuming 10:1 supplies more fuel over the 8:1 correct?<hr></blockquote>
The 8:1 is the universal one that PD sells. Most us PD owners here probably have this.
The adjustable one, is that from Vortech?
Cartech sells a nice adjustable one as well.AIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSD
I found a rebuild kit for sale:
http://www.superchargersonline.com/p...ber=V6Z270-010
I need to rebuild the FMU I have since my A/F ratio was super lean on my recent dyno.
I'm selling this blower to a local 3.8 bud and want to make sure I get the correct ratio installed when I rebuild the FMU.Michael Huff<br />92 RS, 98 V6, 97 SS, 00 Z28 <br /> <a href=\"http://www.carolinafbodyclub.com/\" target=\"_blank\">http://www.carolinafbodyclub.com/</a>
Hey Ironman check out my post in the JohnD power rap section. I got my fuel pressure from 100 to 70 with just a connecter T and PCV valve.Powerdyne 98 a4 convert<br /><br /> stock 16.6 @ 86 <br /> <br /> 6 lbs boost 15.1 @ 90 <br /> <br /> 04 A4 2.73 geared white Corvette Coupe<br /> <br /> stock- 13.5 @ 103 <br /><br />LS6 conversion-13.1 @ 107 <br /> <a href=\"http://members.cardomain.com/greenglow98\" target=\"_blank\">http://members.cardomain.com/greenglow98</a> ( pics of intercooled powerdyne)
