l67 shortblock a good start for high boost application?
I have found an l67 shortblock with 100000miles on it for $250CAD(about 180US)....
Is that too high miles for the money? Would it give me a good start for building a high boost turbo application? (15-18psi?)
Are the L67 cranks stronger than ours?
thanks
1997 silver Camaro RS<br />|T-Type Powered|<br /><a href=\"http://www.kwfbody.com\" target=\"_blank\">Looking for a local F-Body club in K/W, Ontario, Canada?</a>
So basically i'd be buying pistons and rods for that... the rest is the same as mine, but higher mileage..
Okay cool thanks.
Originally posted by CaffeineAddict: Its not worth buying the whole block, you can buy the pistons and rods for around 600$ Get L32 rods
$600 is a LOT more than $180 no?
Could I build up the block to swap into my car? or just strip the good parts out for mine?
L67 injectors are located in the heads. It's not a better location, just the only place they could put them because the blower took up to much intake space.
