2000 firebird? 3.8 liter v6...would be nice if someone had links to low end/mid end/high end super/turbo chargers...whatever puts out most hp...
best turbo/super charger for....
that alittle hard to answer cause i dont think anyone has done any of those with a stock car so its alittle hard to compair. Tiago's turbo kit is a good way to go with that side and the RKsport powerdyne kit is good along with a ATI Procharger kit for an LT1 w/ some changes is good too.
it all depends on how extreme you want to go with your set-up. I personally like turbos better because they don't take hardly any power from the motor and are capable of producing alot of boost. but a stock motor can only handle about 10psi with stock internals. so again its basically how much boost you want to run.1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
On 91oct gas
6psi 255hp and 290tq ~5000rpms
7psi 293hp and 304tq ~5000rpms
With 114 gas
13psi 332hp and 396tq at ~4200rpms
At 15psi we got 352hp and 416tq at 4400rpms
http://www.camarov6.com/ubb/ultimate...=001442#000000www.turbov6camaro.com
1997 3800 Series II Camaro
You aren't gonna be running around with 114 oct gas on a normal basis though, especially with gas prices like they are. The 91 oct numbers are probably more the norm for the kit. I want one, but money doesnt grow on trees :(AIM: Alientr8tr<br /><a href=\"http://www.cardomain.com/memberpage/583450\" target=\"_blank\">1998 Camaro 3.8L</a><br />Flowmaster 80-series, !FRA, Eibach Springs, KYB AGX, SLP sway bars, 3.42/LSD, Wings West kit, Z06 Motorsports, Silverstone Metallic paint<br /><a href=\"http://www.shift5.com/\" target=\"_blank\">Shift 5</a> - My Band
but you could do 10psi on pump gas the would put you about 320 at the wheelswww.turbov6camaro.com
"On 91oct gas
With 114 gas
At 15psi we got 352hp and 416tq at 4400rpms"
Strange to see how 1 psi can make so much more power from 6 to 7 but from 7 to 13 and race gas it produces about the same increase. I dunno maybe it's just me...\'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
Originally posted by 99v6cam:
"On 91oct gas
With 114 gas
Strange to see how 1 psi can make so much more power from 6 to 7 but from 7 to 13 and race gas it produces about the same increase. I dunno maybe it's just me...www.turbov6camaro.com
first of all teh 255 rwhp 290 rwtq numers were at ~5 psi. Also on teh 7 psi run that netted 290 something rwhp and only 300 tq , the tq was so low because believe it or not they ran out of gas on the dyno during that run. Yes when they shut down the car, it would not run any more ahahhaa. After a fresh fill a second 7 psi run netted 294 rwhp and 360 rwtq, noticee the tq increase with fuel. Same problem happened on the 15 psi run when they locked up the injectors the tq is probably low to what it could be under good fueling.
So with a rebuilt motor, forged internals, 5 angle valve, turbo cam etc... and 15-18psi, you'd have to run higher than 94, except perhaps in winter? :D1997 silver Camaro RS<br />|T-Type Powered|<br /><a href=\"http://www.kwfbody.com\" target=\"_blank\">Looking for a local F-Body club in K/W, Ontario, Canada?</a>
Oh, and hopefully by then... some custom pcm tuning [img]smile.gif[/img]1997 silver Camaro RS<br />|T-Type Powered|<br /><a href=\"http://www.kwfbody.com\" target=\"_blank\">Looking for a local F-Body club in K/W, Ontario, Canada?</a>
maybe not if you dropped your compression1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
