I think my Turbo's messed, have you heard of this before?? - FirebirdV6.com/CamaroV6.com Message Board
  • I think my Turbo's messed, have you heard of this before??
    To make a long story short, I had some body work on my car which included installing new battery cables. Anyways, on my way home from picking up the car it seems as though they accidently pushed the coolant cap of its track.... so on the highway coolant blew up in my engine bay, knocking my serpentine belt off, and at the same time slitting my oil feed line. I had the car towed to my house. The car maybe ran for 10 sec with a slitted oil line, i think there was still a little oil getting to the turbo because the whole line wasn't completely cut. Anyways, so i had coolant and oil all over the place.
    When i got home i undid the exhaust clamp and noticed some carbony sludge that was like tar. It wasn't from oil flooding because i had that happen with my old turbo. There wasn't lots, but enough to make me wonder wtf. Anyways, i'm thinking it might be old oil that was in the my y pipe from the old turbo (The new turbo has about 70 miles on it since the old turbo).
    We cleaned everything up. Used some carb cleaner on the turbo (exhaust side)to clean up some of the sludge. There wasn't too much of this sludge, and we're pretty sure that it isn't oil cause it doesn't smell like oil. But again it's really black, some of it is liquidy. We know it's carbon for sure, but not sure y it's liquidy. Anyways.... it's seaping through the cracks (where the bolts attach the two pieces of the exhaust chamber) slightly. Not sure exactly wut it is.
    We took the car for a rip. My idle has been rough for awhile now(still can't figure out why), it might be running rich, not sure. But we hit about 6 psi and it pulled nicely. The BOV was shooting off and all, one problem is that I don't hear the turbo whining anymore. Do u think that might be from the sludge or carb cleaner we used? I really liked hearing it spool up, but not sure why it went away. It does spool though because we we're making some nice boost. I wonder if that sound will eventually come back, it used sound great. I can turn the turbine freely by hand no problem without any obstructions, it spins normal just like new.
    Anyways, this sludge has me worried a little bit, not sure wtf it is or y it's doing it. Do you have any ideas? Is it my rough idle causing some problems, cause it still sounds like i have a cam in my car. It doesn't look the same as when it was flooding with oil, so i don't think it's that.
    Sorry for the long msg, i'm just not sure what to do next.
    thanks, i apprecaite any help.
    Perry
    p.s. I am running an FFF kit, and i do have a leak in my headers. Before this coolant/oil leak, i could hear it spool just fine.
    Perry V.<br />\'97 Chameleon Bird w/ too many toys to list.<br /><a href=\"http://www.geocities.com/umvagia0\" target=\"_blank\">http://www.goecities.com/umvagia0</a>
    sound like "cloking" but that is useally in the turbo where the oil is at...
    leaking headers will suck in moist warm air the could make the carbon do that i guess. .
    BTW hows the kit working for you... ad how did you blow the first turbo ?
    www.turbov6camaro.com
    1997 3800 Series II Camaro
      A piece of weld came loose in my y pipe and bent the crap out of my turbine. It was freak unlucky thing i guess.
        most garrett's are going to get a little bit of oil blow by it's no big deal...
        that's probably your sludge. the oil mixes with the carbon adn stuff and creates a thick goo.
        I'm still trying to figure out how coolant cut your oil line in half and caused your serpentine belt to come off.....
        Jason<br /><br />\'99 Pewter Camaro<br />\'93 V8 S-10
          Thanks for the replies guys. PiercedJD okay that would explain my sludge. Thankfully nothing's wrong there. My coolant flew all over under my hood, knocked my belt off. And when my belt fell off it clipped my oil feed line.
          Anyways, do you have any idea of why I lost my whining sound? I mean i still make normal boost, and the impeller spins freely like it was new. But y did that sound go away. That's weird. I really miss it :(
          Thanks again for the replies.
            Check for shaft play in the turbo, see if you can move it up and down any noticible amount.
            hybrid - \'\'hI-br&d - The offspring of a cross between species.
            Co-Founder West Coast F-Bodies
            West Coast F-Bodies Car Club - WCFB Message Board
              umm does it spool faster/ slower
