I dont know if this is a dumb ?....but if you have a blow off valve do you still need to do a throttle body pcv bypass?
pcv bypass ?
Yes, you will still get high pressure in the crankcase. It's been known to shoot dipsticks out. Use the mod posted here: http://home.comcast.net/~grayman99/TB-PCV.html
I did, it's easy, works great and costs about .80 cents for the plug, and about 3-4 dollars for a new TB gasket. I got a 3/8" tap for 2 bucks and a handle for 7. (I was going to use it for other taps too).
Dont forget to get an oil breather cap. I took off my oil fill cap, and put it right on the plastic neck that comes off the valve cover, so it's still easy to add oil. [img]smile.gif[/img]Jessica :)<br />Kansas: There\'s no place like home...99 Firebird Blown/6lbs, Eaton w/3.42\'s CI headers Z28 Exaust<br />CAI, #36 injectors Intense PCM
