Thinking about turboing it... - FirebirdV6.com/CamaroV6.com Message Board
  • Thinking about turboing it...
    i miss having a turbo car. if i were to turbo the 3.8 i would want something moderatly fast..... not something so fast that i will constantly be breaking stuff. my eclipse was constantly needing to be working on. this car also needs to get ok gas milege and needs to be very reliable! can any of ya'll point me in the right direction? thanx!
    1999 Camaro Silver 5spd<br />Appearence Mods:<br />-Clear Corners -Tail Lights off a 93-96 Camaro -Painted Black Calipers w/ Silver Camaro Decal on front ones -Black Camaro Rear Fill Decal -Silver Camaro Front Fill Decal -Painted Silver Interior Pieces -RKSport Shift Knob<br />Performance Mods:<br />-Eibach springs -Whisper Lid -Removed MAF screen -Free Ram Air -Trans Am Dual Exhaust -3\" Cutout<br />Stereo System:<br />-Eclipse 8v Head Unit -Eclipse 87series 12\' Subs -Rockford Fosgate 800wt amp (subs) -MTX 225wt amp (highs)<p>AOL IM is jay eub, msn messenger is banks_2003@hotmail.com
    found a kit for 3000 bucks on forcefedfab.com
    i will prolly also need a lsd, and clutch.... anything else you guys would think of?
      Yeah I would do a good gear, and an LSD, a better clutch, and some nice tires. Is your exhaust suitable enough for a turbo? Good luck. ;)
        well i have the cutout so i am guessing that is good enough? i will get a highflow cat. does the FFF kit come with turbo headers and such?
          Tiago (the guy who make the kit on this board) should chime in soon
          but to answer your qustion, the kit is a full bolt one everything you need is inculuded.
          no he does not use turbo headers, uses a custom y pipe. becuase to make turbo headers for our car would be costly and the main reason i think it would be harder to install the kit and you would have to remove power sterring and AC
          the kit he sells you dont have to remove a thing bolt it in and [img]graemlins/burnout.gif[/img]
          www.turbov6camaro.com
          1997 3800 Series II Camaro
            supposedly the 3.8 kit by FFF is pretty reliable.
            all parts are quality parts. radcat (3.8 prototype car) has had his on his car for what? a year now, no problems. he even pushed 14 psi with higher octane no problems.
            im sure you will need to upgrade Some parts such as fuel pump (included in the kit i believe) and if you have a manual, upgrading the clutch is highly recommended. and depending on how you want your intercooler mounted you may need to cut your front nosecone for a front mount type setup.
            but for speed AND reliability. you cant go wrong with the 7-8 psi settings.
            and forward sweeping headers wont necessarily yeild you your ac or powersteering. i dont think shane took out his ac nor PS. but he did that totally custom, and took him quite a while to complete.
            96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view&current=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
              also, cutout or not, you can always just run open downpipe.. i cant imagine the exhaust being too extreme considering the turbo deadens the sound and acts like a resonator.
              that way, you can ditch the whole exhaust making a nice weightloss [img]smile.gif[/img]
                the kit bolts on to 00 and newer exaust manifolds. These flow well and wont leak.
                  so pretty much all i will have to buy is the tubular headers a clutch and a high flow cat if i don't run open downpipe? lsd would be good too? but is that about right ya'll?
                    also, if i didn't want to put the intercooler FFF supplies, has anyone ever tried using an air to water intercooler? it looks like the way FFF mounts their intercoolers it could affect the cooling of the radiator?
                      there is no way to can fit a pump for the air to water in our motor bay,
                      the inter cooler does not block the flow for the raitor it, it uses air hitting the front of the car, the radotir gets its air from under the car, that why you have the HUGE scoop under there
                        yea i know but in the pics on FFF they have it mounted right there where the air goes up to the radiator.....
                        http://www.forcefedfab.com/images/PI.../DSC00137.html
                        see what i mean?
                          another pic of the same thing...
                          http://www.forcefedfab.com/images/PI.../Dsc00723.html
                            won't do anything. air goes in the ICr and back out, to make car more of a sleeper you mount it under there....
                              yea i don't think i want it to be mounted in the grill
