can you put two t4 turbos on the fff kit with minor modification to the y pipe of do you have to make a whole new custom kit for the setup that i want to do? any help is appriciated. thanks.
? about the fff kit
im not sure how you would run the turbo's off of their kit that is only designed for one turbo. i'm sure it could work theoretically, but it would involve a lot of custom tubing and you would be building most of the kit yourslef anyway, so why would you go with their kit?
if you were up to making your own tubing, you can buy lengths of individual mandrel bent bends from jcwhitney. all you'll need then is access to a welder, a saw of some sort and a lot of patience to get it to work out. I'm plannin on going that route myself. good luck if you go thru with this tt setup.. itll be sick as hell...Phill<br /><br />95 camaro... need money for turbo project... <br />94 S10 Blazer - winter beater - infinity system to be installed soon<br /><br />\"The man who says it cant be done should not interrupt the man doing it...\"
no this will not work....... just stay with one turbowww.turbov6camaro.com
1997 3800 Series II Camaro
hybrid - \'\'hI-br&d - The offspring of a cross between species.
Co-Founder West Coast F-Bodies
West Coast F-Bodies Car Club - WCFB Message Board
