Boost gauge - FirebirdV6.com/CamaroV6.com Message Board
Boost gauge
  • Boost gauge
    Anyone ever have their boost gauge fog up on them? Mine did on the way home from work yesterday. Weird. It was pretty muggy out and was raining off and on all day. Just curious.
    Jessica :)<br />Kansas: There\'s no place like home...99 Firebird Blown/6lbs, Eaton w/3.42\'s CI headers Z28 Exaust<br />CAI, #36 injectors Intense PCM
    I think thats a pretty damn good sign that somethings not right with your vac lines.
    -Kevin<br /><a href=\"http://heinz.no-ip.com/Car%20Pics/IM000117.JPG\" target=\"_blank\"><b>\'96 White Camaro RS M5</b></a> <br />GTP Shortblock - T3/T4 -6psi Intercooled<br />Open Downpipe
      I never heard of a brand new gauge mounted on the inside of the car foggng up. i don't live in the tropics, but that doesn;t sound right.
      If all your gauges (including dash gauge) were fogged up because you had a puddle of water in your car that would be different.
      I still never heard where you attached the MAIN VAC source to. Is it over on the passenger side REAR manifold like I have mine in my pics?
      I wonder if that BOV VAC valve is leaking at it is presurizing the inside off the boost gauge...doesn't make sense though. The boost gauge should not leake from the back (npt fitting) to the inside of the gauge face. very odd.
      01 Firebird A4 3.42
      Powerdyne @ 6 PSI
      and other mods
        Yes, I hooked to the pass rear vac, it has a 45 degree elbow on it.
          Hey sis, thought i'd find you here. Are you done with my floor jack? Kim needs it for her SS. You don't answer your phone. Did you go to Key West after all? Call me....Later, J
          Jon
            [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img]
            so FUNNY
            this is kinda sad the only way your family can find you is this web page
            FBV6 and Jess family &gt;&gt; [img]graemlins/slap.gif[/img] &lt;&lt; Jess
            www.turbov6camaro.com
            1997 3800 Series II Camaro
              Hey, be nice...I left my phone at work Friday. I only have a cell phone. It was a real drag. Had to use the payphones all weekend. :(
              [ June 13, 2005, 09:53 AM: Message edited by: jessica2112 ]
                i'm nice i just think it's funny
                  Yeah, you do have a leak somewhere. Everything should be tight and sealed. Definately check your vacuum. This could be your solution as well.
                    a test of the vacumm lines would be to disconnect all the vac lines from the main vac source. reconnect the stock vac line connector to where it belongs. this means you will not have FMU or Boost gauge or BOV...but the cars original vac lines will be tight and secure. test drive the car. maybe disconnect the battery while you are re routing the vac lines as well. don't put the car into high boost. keep it below 4000 rpm. see if the sluggishness has gone away.
                    I don't have a lot of experience with BOV systems, But it might be a good idea to try this. you wont harm the FMU or the Boost gauge by just disconnecting them from VAC source.
                    Regardless of how the test turns out you still want to hook everything back up when you are done with the test.
                    Concerning the intake manifold VAC source...
                    I noticed on my car that the stock VAC conncetor elbows were larger than 1/8". I used a multiple sized 'T' adapter. this type of adapter has three barbed ends and each of them starts off as 1/8" and gets bigger...for adapting different sizes of VAC hoses together. I trimmed on of the barbs off to expose a larger diameter barb. I used the larger barb for the STOCK connector elbow in order to achieve a tight seal. I have pics of this and the multi size adaptor T on my website...on the boost gauge or FMU guide web page.
                    if you have vac leaks....at the manifold....your car will run goofy.
                    01 Firebird A4 3.42
                    Powerdyne @ 6 PSI
                    and other mods
                      it could be the gauge itself..shouldnt the side of the gauge that you read from be air tight from everything else?..
                        I'll try the test tomorrow, I didn't get a chance to read your post till now. Dang. I had today off too. I think my vac tubing is too small to begin with. It was the only kind that Advance had at the time. I have a 3 way by the main vac source. 1 to origional vac line, the other to the boost gauge and the last to the fmu. However, I ended up having to split it again to hook up the BOV.
