Would this turbo work on and F-body like ours... - FirebirdV6.com/CamaroV6.com Message Board
  • Would this turbo work on and F-body like ours...
    ...and if it did would you trust it? I know that there are some more parts to be purchased before something like this could be operational, but could it be fitted to our cars?
    Might consider this.
    http://cgi.ebay.com/ebaymotors/ws/eB...tem=1871259534
    1995 Pontiac Firebird
    hmmmm that turbo is kinda expensive man...and it is waaaaaaaaay tooooo big for our cars. I believe it says its a T70... that is so big, what you want is like a T3/T4 hybrid or something along the lines of that. Again that is a big turbo, you wont be able to get that thing spinning fast enough.
    [ October 31, 2002: Message edited by: 97Pcam6 ]</p>
    Email: Preki1212@hotmail.com
      Yep, a T70 is way to big. A T3/T4 followed by a straight T4 are the two most ideally suited for both the 3.4L and 3.8L.
        formula96 did it with the gn turbo
        cracked a head too
        2000 NBM M6 Camaro Z28<br />323/335
          Correction...Cracked 2 heads [img]smile.gif[/img]
          New Car--- 2000 Trans Am M6--SLP Lid, K7N Filter, 160 degree Thermostat, Loudmouth Exhaust, Smooth bellows, MAF ends, ASP Pulley, 4.10 gears, Y2K Chrome Vette Wheels, 2\" drop.. More to Come<p>Dyno <br />325 RWHP <br />325 RWTQ<p>Cardomain Site <a href=\"http://www.cardomain.com/id/formulao96\" target=\"_blank\">www.cardomain.com/id/formulao96</a>
            Whoa!!! You cracked both heads! you da man :D
            <b>99\' Black Camaro SS</b> <br />M6/T-Tops - SLPLid w/K&N | Hurst Billet Plus w/ LSS | EGR Mod<p>Black 97\' Camaro T-Tops (RIP)
              yea but you also had alreayd had cracked heads before the turbo you just didnt know it =\
              t 70 is way to big if you want a good turbo just get a t3 or t3/t4 hybrid t3
              s are cheap off ebay $~200 ive also seen em go for 50$so yea there are many of the little things comeing off little cars, like the talon tsi turbos are hella cheap and so are the intercoolers
              91 Eagle Talon Awd Turbo 5 speed FOR SALE 6000$<br />Looking for a Fiero GT<br /><a href=\"http://www.swdsm.net\" target=\"_blank\">www.swdsm.net</a>
                My turbo is a KK&K model, with identical dimensions to a T3.
                project starts this march.
                2011 Camaro LS 6M, in black.
                  Thanks guys for the info. This guy says at the end of his description that he has other turbo's for sale, but I would like to make sure of credibility. So a T3 or T3/T4 hybrid is a better choice? I'll ask him later next week about that.
                    If you were going to build a racecar, the T70 would be better. But for a street car that will see track use once in a while, you will want to go with a T3/T4 hybrid.
                    EDIT: Explanation.... if you plotted some points on a compressor map of the T70 you will most likely see that you are operating to the left of the surge line almost all of the time unless you were running some insane boost levels... the T70 is a turbo good for 800HP applications... that is why I said that it would be fine if you were building a racecar. With a T4 series compressor, you should be operating at good efficiency at all rpm for any reasonable level of boost.
                    [ November 01, 2002: Message edited by: HAZ-Matt ]</p>
                      <blockquote>quote:</font><hr>Originally posted by HAZ-Matt:
                      <hr></blockquote>
                      damn you know a lot.
                      :eek:
                        <blockquote>quote:</font><hr>Originally posted by Mogobs30th:
                        Thanks guys for the info. This guy says at the end of his description that he has other turbo's for sale, but I would like to make sure of credibility. So a T3 or T3/T4 hybrid is a better choice? I'll ask him later next week about that.<hr></blockquote>
                        Go get "Maximum Boost: Designing, Building and Testing Turbocharger Systems by Corky Bell" and read it cover to cover, every last page. Its everything you ever needed to know about turbocharging a vehicle.
                          He's got a t3/t4 hybrid here.
                          2000 Magnetic Red II Automatic Coupe
                          Best(s): Coming soon
                          99 Bright Red Turbo Firebird A4 T-Tops
                          Best(s): N20 - 14.01 @ 97.32 (1.64) Turbo - Coming soon
                            I have a question...
                            I keep hearing people say that some turbos are just too big for our cars... why is that?
                            I thought that if you keep the boost under a safe level (like 8 or 9), that it wouldnt matter how big it is. Is it because there isnt enough exhuast to move a turbo that big? Or is it because the turbo would make boost too late? Thanks.
                            All gone :(<br />Best ET ever: 14.3 (I think)<br />----------------------------<br />Check out my site for exhaust clips, burnouts, and pictures, and the supercharger throttle body mod.<br /><a href=\"http://www.geocities.com/net_addict/index.html\" target=\"_blank\">Click on the Firebird</a>
                              <blockquote>quote:</font><hr>Originally posted by Riles:
                              <hr></blockquote>
                              Bingo.
                              AIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSD
