'00-2002 27# multec2 (long) 'plug and play' injectors found by zlexiss - FirebirdV6.com/CamaroV6.com Message Board
  • '00-2002 27# multec2 (long) 'plug and play' injectors found by zlexiss
    I just wanted help make sure that the word got out on these.
    http://www.camarov6.com/cgi-bin/ulti...;f=16;t=003618
    Thanks zlexiss!
    You [img]graemlins/rock.gif[/img]
    LTS # = MBB-61121 = 24 Lb/hr @ 43 psi (27# at 50 psi...our fuel pressure)
    $24.95 each, exchange ($5.00 core) + S&H.
    Feel free to call.
    Doug Garriott
    The Injector Wizard
    Linder Technical Services
    888-809-FUEL
    http://www.lindertech.com/
    01 Firebird A4 3.42
    Powerdyne @ 6 PSI
    and other mods
    looks like a good sticky. ???
      Thanks for the link here in FI.. though like you and I pointed out, the 27# might not be enough for most FI guys, but would be perfect for a heads/cam or someone running maybe a 100 shot..
      2001 Pewter Firebird Y87, M5
      Go Sabres!
        I am no 'injector guru' so be warned...
        but, If 25# injectors are enough for an engine rated at 340 crank HP wouldn't they be enough for an engine under boost that develops less than 340 crank HP?
        I say this after consindering my current mods and their max potential while running at 9psi and that as an air pump the two engines (to me) seem like they would need the same amount of fuel flow to keep up with the air.
        I also know that L67's come with 36# injectors but I think the newer ones might have 32# injectors.
        I admit i know little about peak injector perfomance or pulswidth, etc. I am just going off basic hp ratings in comparing injector sizes. Perhaps I am way off base becuase i am comparing a NA engine to a forced induction engine in the exapmple above.(?)
        Any input is appreciated.
        I would not buy new injectors 'just to get rid of the fmu' yet remain at 6psi. I would upgrade injectors, though, in order to increase the psi to 9 or so and dump the fmu becuase i don't want to run around with a fuel pressure of 118.
        01 Firebird A4 3.42
        Powerdyne @ 6 PSI
        and other mods
          Because they have 8 and we have 6 [img]smile.gif[/img]
          Go Sabres!
            </font><blockquote>quote:</font><hr />Originally posted by grayman:
            Because they have 8 and we have 6 [img]smile.gif[/img] </font>[/QUOTE]DOH!!!!!!!!! [img]graemlins/twak.gif[/img]
            of course....See I told you I was an injector newbie.
            340\8 = 45 'HP' per injector on a v8
            340/6 = 57 "HP" per injector on a v6
            I guess I should knuckle down and bone up on injector flow rate calculations. I would have to anyway if I do switch them out because I would be the guy tuning the car.
            01 Firebird A4 3.42
            Powerdyne @ 6 PSI
            and other mods
