Well I finally got the 2.6" grooved pulley put on and it is outstanding. In 1st gear I was getting 7psi and when I hit 2nd it shot up to 10 psi and it just stayed there until I shifted to 3rd gear. But heres where I had a problem, at the top of 2nd gear when I was about to shift, I heard the engine making some funny noises under the hood, I think it might be because I don't have my walbro 255 in yet and it might be running lean, I don't know but I think I'll put the walbro in very soon [img]smile.gif[/img] . Thanks again John D for redesigning the belt, what a huge difference it makes.
2.6" pulley= 10psi
2.6" pulley= 10psi
96' Camaro M5 to A4 conversion, alot of mods . GT35R Turbo full suspension. Built engineTags: None
Not yet, Wed I should get the pump in, so maybe on Fri. I can get it on the dyno. What size pulley are you going to go with?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
right now I only have the 6lb pully that comes with the kit..
Once I get comfertable with the car.. and get it intercooled, get a bov, and tuned I will push it up to the 10lb pully.. and I will do the JD wrap.. then leave it at that..
I am soo close to finishing my install Its making me crazy..
what do you have left to do? The only thing I want now is the HP Tuner software.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I need time mostly..
still gota install the pump, and plugs before I put the blower on..
so.. I am one good weekend away from finishing the install..
You're almost there, which pump did you get, the reg. or the high pressure, I got the high pressure.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
which BOV are you looking at, maybe I should look into one , since I'm now getting the boost I want.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I am looking at a few..
To be honest I have been doing side work for a new shop thats gunna give me a awsome deal on one.. so.. I am gunna go with whatever they sell me.. before that I was looking into the turboXS type-s.. its like $100 and They are literaly 2 miles form my house.. I was talking to one of the guys there jermaine, who is a memeber of my local car club.. he said its the best one the sell.. its just not as loud as others..
I got the walbro 255 that TSP sells.. not too sure if its the high pressure one or not.. I "think" it is.. its not a huge differnece anyway..
I would get a BOV if i was running 10 lbs.. powerdyne reccomends it..
Do you know with the Bov, do you let it vent in to the atmosphere or do you recirculate it into the intake(pressurized side) or where your air filter is at(side)?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
here
http://www.turboxs.com/type-s_blow_off_valve.htm
check out the little diagram on that page.. and pretend the turbo isent there..
I dont think that valve supports return.. it looks like an atmosphere only setup..
you can get it in other colors besides purple too..
Thanks for the info08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by AllTheGoodNamesAreGone:
I am jsut gunna vent it to atmosphere.. I am lazy like that..
I am only in it for protecting the throttle body and the blower..
Be careful until you get that upgraded fuel pump in there. You need it at 10psi for sure.\'98 A4 Camaro v6->v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
